Where can I get it replaced on a Sunday?
Chances you're SOL on a Sunday.
Yeah that's what I figured, found a 24-7 glass replacement place but they aren't actually, they said they have no tech's on today.
Kind of on topic:
I had my rear passenger door window broken on a beater. $200 something to replace
Soon after some f*cker left a giant dent in the same door. An entire door replacement from pick n' pull with intact glass: $40. I just lucked out they had the same color and trim level (manual lock & crank window)
thats usually the easier option if you can find the part or live with it being a different colour etc... otherwise you could just replace the window, but thats a lot of work compared to the entire door. But that only works if it was a door window and he didnt say it was a rear door window, he said back seat drivers side, so if it was a sealed window in the rear quarter (mostly coupes) then that doesn't really help anyQuote:
Originally posted by jwslam
Kind of on topic:
In these situations basically all you can do is use some cardboard and tape or something to seal the hole until you can get it in to a shop, and don't leave any valuables in there so nobody has a reason to go through the already broken window.
