Quote:
Originally posted by arian_ma
I always found it easier to lean forward on grooms and lean back in powder.
Also, max, get a stomp pad immediately. I bet you won't fall off the chair lift anymore after you do. How far apart are your bindings from each other, and where on the board is your weight? (IE are the bindings exactly in the middle, or set a little back, etc)
I've only been in pow maybe 3 times since I started last year. Ya I learned that you definitely have to put a bit more weight on your back leg to have your nose up to keep it from digging into the snow and causing you to either get stuck or bail. But falling in deep pow is so nice haha, like falling on a pillow, cold pillow albeit but soft none the less.
