Some of my outlets stopped working - Beyond.ca - Car Forums
Results 1 to 20 of 28
Thread: Some of my outlets stopped working
    Nov 2005
    2015 Hyundai Veloster
    Default Some of my outlets stopped working
    I woke up yesterday and my bedside clock was off, that's weird. When I checked the outlet I noticed it wasn't working. I checked some others and this is what I got:
    NOT WORKING
    - master bedroom outlet 1
    - master bedroom outlet 2
    - master bathroom outlet
    WORKING
    - master bedroom light
    - master bathroom light
    - master bedroom closet light
    - everything else
    I do know that everything not working is on the same circuit so I thought it was a no brainer that a breaker got tripped. When I checked at the panel I realized nothing is tripped, it's fine. The outlets just aren't working on that circuit. What would cause that?
    Originally posted by Go4Long
    Originally posted by blitz
    Apr 2004
    rs4, ram, 675f3
    How old is your house? go back to the panel you should have a arc fault breaker in there. Flip it back and forth a few times. Typically all bedroom plugs are on the same circuit. Bathrooms will be on another breaker.
    Maybe your bathroom plug is tripped and your bedroom is on it. Try pushing the button on the bathroom plug. Would have to be in a older house for this to be the case
    Jan 2007
    NW
    06 F-150
    GFCI in the bathroom? Hit the reset button and see if you got power.
    Only 15min from Aspen!
    Nothing interesting anymore
    Did you physically move the breaker? They can trip without appearing to have.
    Nov 2005
    You guys were right, it was the GFI but I didn't think to check it because the GFI switch is on an outlet in the secondary bathroom next to the bedroom. My girlfriend was getting ready in there right before I woke up, she had a meeting in Edmonton so she must have been using too many devices. Problem solved.
    Apr 2010
    Alberta
    Has AWD
    u have one of them fancy archway openings to your bathroom i bet I learned that one from the Journeymen i worked with. Had never occurred to me prior to that day he explained it to me. 1st year at SAIT should be fun learning all the code stuff.
    Apr 2004
    rs4, ram, 675f3
    It's bad practice to have the bedrooms on with the bathrooms. When I wire a house all the Gfi's go on a circuit. And all the bedroom plugs go on their own circuits.
    Stampede Central
    is pretty sharp lookin'
    OP going on again about this GF nobody has seen pix of...
    I only have one bathroom with a GFI
    The home inspector told me all the outlets in other bathrooms were protected by the same one. Is that normal?
    Easier said on new developments.
    Reno's, sometimes you just work with what you got.
    Got a bathroom fan wired to kitchen plug GFI. Guess it's safe. But if you run a toaster, coffee maker and fan all at once, it'll pop.
    Easy to just move the toaster. House is 1950s. Developed basement.
    Jun 2004
    21 CX5 GT Turbo
    Another thing that could cause part of your circuit to fail is that one outlet fails and the outlets and lights after that one would be dead too. I had that happen in my parents place.
    The outlets when they were wired back in 1990 when the house was built was done with the push in quick connects. One of the quick connect connections started to fail and everything after that stopped working. Worst part, the fucking circuit spanned all 3 levels on one side of the house, was not fun to troubleshoot.
    Nov 2005
    What would the opening have to do with the circuit?
    Because it affects the electrical code and how the plugs in the bedroom have to be wired...
    Elbonia
    Jeep of Theseus
    Yeah that's how my place is wired, but MGCM's post seems to indicate there's a bit of code funkiness that involves arched entrances to bathrooms.
    Probably something to do with them being considered the same room?
    I think its to stop idiots from electrocuting themselves by plugging toasters into outlets in the nearby room and dropping them into the bathtub. i think its a distance thing from the bathroom.
    I'm not an electrician but i think the presence of a door changes things from what my brother ( electrician ) told me.
    The outlet right outside my bathroom in my bedroom ( no physical door) is on GFCI, 2013 build.
    1999 build, master bedroom on separate circuit from the bathroom due to fancy archway haha. Both master bedroom bathroom and 2nd bathroom are on the same GFIC plug, which is located in the other bathroom. Had this same headscratcher 10 years ago.
    Sep 2012
    Yes, it's normal. A GFCI outlet can protect 2-3 others (maybe 4, can't bother to remember).
    Recent code requires bedroom receptacles to be on an AFCI, those things are not compatible with GFCIs, so anything newer will have separate circuits (hopefully).
    Nov 2005
    Interesting, I was wondeirng how you knew the bathroom door was arched. There isn't actually any door on the bathroom, it's just an open archway from the bedroom.
    Stampede Central
    Because a square entryway without a door looks awkward and causes unnecessary structural stress
    Cause lets me honest, its definitely loadbearing and not just painted drywall...
  1. Heater stopped working in my house...
    By Mr_ET in forum General
    Latest Threads: 02-09-2008, 12:27 PM
  2. My deck stopped working
    By DGill in forum In Car Entertainment / Electronics
    Latest Threads: 04-14-2007, 08:24 PM
  3. Bov Stopped Working
    By cressida_pimpin in forum Forced Induction Talk
    Latest Threads: 03-20-2007, 08:12 PM
  4. DVD-R drive stopped working
    By arian_ma in forum Computers, Consoles, and other Electronics
    Latest Threads: 11-20-2006, 10:16 AM
  5. Turn Signals Stopped Working
    By Envitro in forum Calgary MR2 Owners Club
    Latest Threads: 05-25-2006, 07:28 AM
