doesnt get used that often...Originally posted by jwslam
You don't do sheets weekly?
Considering we have a tenant in our basement who works from home and has his own facilities, I expected far worse. We're generally on average, or in between the average and efficient homes.
Yeah, I'm saving the environment... that's right.
Hmmm this doesn't make me happy. WTF
Mine doesn't have a tab for comparable places.
Can't complain
Suspect it's mostly cause it's just me and the gal. Vs the other houses with kids
Mine isn't spectacular either.
402 KW, 38% more than similar homes. 850 Square foot condo. 2 people in our house. I have to assume its mostly the appliances. The fridge we run pretty cold, run the bathroom vent fans a lot. We have an electric HVAC which explains a lot. We run the house at 23 Celsius almost all the time.
Changed the home config so it will take another billing cycle to better compare to similar units I am guessing.
Mine is a condo, i guess i do alright
Any my Ecobee must be earnign its keep.
User title molested by Rage2.
So either the basement tenants are cranking their baseboard heaters or my electric garage heater is on 24/7
Seems The Gimp likes it warm.
Yep I only set the garage to be 7.5ºC and it's fully insulated so I doubt it could be all from that.Originally posted by jwslam
2000kWh
Even at 7 cents that's $140 in usage alone ignoring all the fees
The only other thing that uses a ton of electricity would be the previously mentioned baseboard heaters in the basement suite I would think... Hell the washrooms have underfloor tile heat but I have them always off in order to save costs.
All those TVs are a huge energy hog ....Originally posted by C_Dave45
I'm way higher than anyone I know.
lolOriginally posted by flipstah
I have more than one set of sheets. I'm not a cheap fuck.
Built with Chopsticks
Originally posted by adam c
Line goes up, line goes down, line does squiggly things and fucks Alberta"The stone age didn't end because we ran out of stones"
Grow op.
