Beyond.ca - Car Forums
Registration is free! Car Forums - Member Rides Car Forums - Find other members Car Forums - Calendar Car Forums - Frequently Asked Questions Forum Rules and Regulations Car Forums - Search Logout
Beyond.ca - Car Forums : Powered by vBulletin version 2.3.9 Beyond.ca - Car Forums > Car Forums > Performance and Handling > Mechanical > 1989 Nissan Pintara: 3 of 4 cylinders firing
Author
Thread Post New Thread
cjb82
Newbie
What I drive: 1989 Nissan Pintara 2Ltr. Auto
Posts/Day: 0.00
Trader Rating: (0)
User Rating: 100%
Question 1989 Nissan quote:
1989 Nissan Pintara, 4cylinder RWD 2Litre
Only 3 of 4 cylinders firing, checked spark plugs and leads
Not very familiar with cars bit of a noob!
been told possible fuel injector blocked or stuffed
does anyone have any idea of what my problem may be?
If its something engine related, ive had the car 2 weeks and the engine had 2 yrs warranty when i got it so im not too fussed if its something different it may get costly
also does anyone know where i could find online resources for my nissan e.g. diagrams, manuals etc
thanks
cjb82
Report this post | IP: Logged
Old Post 11-09-2004 12:54 PM
cjb82 is offline Click Here to See the Profile for cjb82 Click here to Send cjb82 a Private Message Find more posts by cjb82 Add cjb82 to your buddy list Edit/Delete Message Reply w/Quote
ex1z7
First Gear
What I drive: 98 Subaru Forester, 93 Toyota Pickup
Posts/Day: 0.51
Trader Rating: (1)
User Rating: 100%
quote:
Considering I have the same car, and this is a Candian based forum - I wouldn't be too surprised if nobody can help you. Our car is, I believe, the same as a Nissan Stanza back in Canada.
The problem itself I would imagine would be fairly universal, one cylinder being sketchy for some reason - happens to numerous types of cars...
My advice is go to a mechanic and get a quote, find out what they think is wrong - and how much it'll be to fix it. On here you won't get too much help - you'll have to take it into a mechanic anyways regardless...
Also - more advice to ensure your pintara doesn't die...change your oil pump, pintara's have a nasty habit of leaking ALOT of oil, faulty factory pump - replace that and you shouldn't leak oil (if you are) anymore.....unless it's happened already.
Hope that helps in some way... Just go to a mechanic and get them to figure it out.
__________________
Originally posted by Grogador
Shoulda threw in a "no homo" somewhere... cuz... yeah...
toexistphoto.com
Old Post 11-10-2004 10:24 PM
ex1z7 is offline Click Here to See the Profile for ex1z7 Click here to Send ex1z7 a Private Message Find more posts by ex1z7 Add ex1z7 to your buddy list Edit/Delete Message Reply w/Quote
cjb82
Newbie
Posts/Day: 0.00
Trader Rating: (0)
User Rating: 100%
fuel injector quote:
hi there mate, thanks for the suggestion, i am unfortunately in no position financially at the moment to take it to a mechanic which doesnt help things too much, but with the help of some other local adelaide ppl online i have tracked the problem back to one of the fuel injectors..... its apparently a reasonably cheap part to fix and i can do it myself
thanks for the tip on the oil pump that was leaking so ill tend to that straight away
catchya thanks for ya help again
chris
Old Post 11-11-2004 10:02 AM
ex1z7
First Gear
Posts/Day: 0.51
Trader Rating: (1)
User Rating: 100%
quote:
No problem buddy I've only had to replace a few things on my 'tara, clutch - spark plugs - filters - head work - rack and pinion (twice ) - brake pads - tires - oil pump ... But thats to be expected on a 270,000 km car
These things should last you forever, if anything breaks, parts are pretty cheap ... But yea that oil pump should fix that oil problem up - random problem with Pintara's...Bloody factory
Do an SR20DET swap on it ! bolts straight up , sleeper
__________________
toexistphoto.com
Old Post 11-11-2004 12:34 PM
3G
Banned
What I drive: cd7 coupe
Posts/Day: 1.00
Trader Rating: (39)
User Rating: 100%
quote:
do you guys have them Primeras there too?
__________________
Old Post 11-11-2004 07:04 PM
3G is offline Click Here to See the Profile for 3G Click here to Send 3G a Private Message Find more posts by 3G Add 3G to your buddy list Edit/Delete Message Reply w/Quote
kevie88
Moderator
What I drive: GD + GR WRB
Posts/Day: 0.79
Trader Rating: (26)
User Rating: 100%
quote:
Primera is an Infiniti G20 here..
__________________
Bought not built!
Old Post 11-11-2004 07:54 PM
kevie88 is offline Click Here to See the Profile for kevie88 Click here to Send kevie88 a Private Message Find more posts by kevie88 Add kevie88 to your buddy list Edit/Delete Message Reply w/Quote
3G
Banned
Posts/Day: 1.00
Trader Rating: (39)
User Rating: 100%
quote:
Didn't know that, my uncle has one back in Lebanon drove it over the summer pretty nice car
__________________
Old Post 11-11-2004 08:19 PM
illeagle
Second Gear
What I drive: FG, S14, Caliber SRT4
Posts/Day: 0.88
Trader Rating: (93)
User Rating: 100%
do they both have the same drivetrain?
Old Post 11-11-2004 08:27 PM
illeagle is offline Click Here to See the Profile for illeagle Click here to Send illeagle a Private Message Find more posts by illeagle Add illeagle to your buddy list Edit/Delete Message Reply w/Quote
kevie88
Moderator
Posts/Day: 0.79
Trader Rating: (26)
User Rating: 100%
quote:
No, you could get the SR20DET in the Primera, we only got the non-turbo cars. I always wanted to do a DET swap into an old g20.. that could be fun.
__________________
Bought not built!
Old Post 11-11-2004 09:51 PM
  Last Thread   Next Thread
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Rules:
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
Google
Web beyond.ca
Terms of Use - Contact Us - Advertising Info - Archives - Car Blog
Powered by: vBulletin Version 2.3.9
Copyright ©2009 Jelsoft Enterprises Limited.
Bringing Car Enthusiasts together in discussion on our car forums
One of the largest message boards on the web !
Page Statistics : Page generated in 0.56729102 seconds (51.35% PHP - 48.65% MySQL) with 31 queries.
0 days 0 hours 0 minutes until 2010 F1 Season Begins!
