nitrogen for tires - Beyond.ca - Car Forums
Results 1 to 17 of 17
Thread: nitrogen for tires
    Default nitrogen for tires
    looking for a local store in calgary that can put nitrogen into
    my tires
    May 2004
    2014 Cadillac ATS Turbo
    costco, canadian tire and i believe walmart
    Elbonia
    Jeep of Theseus
    Why the hell would you pay money for that?
    Read: http://forums.beyond.ca/st/209832/nitrogen-in-tires/
    Only 15min from Aspen!
    Nothing interesting anymore
    I found 100% nitrogen didn't give me the results I needed for mad drifting, I found a good combination of 78% nitrogen, 21% oxygen, a bit of argon, a little carbon dioxide made for the best mix.
    Pm me, and I can hook you up with my combo for $30 for a set of 4 tires.
    Apr 2004
    ////M
    Nitrogen filled tires are JDM
    Yo bro, are you from that goat Calgary car forum that get salty over lawn care, land rovers and circumcisions? That's straight fire.
    Oct 2007
    TX
    Camaro 2SS
    Great deal!
    06 civic ex coupe
    My aunt was looking at a used Pilot a Honda dealership in the NW, and the guy wanted to add $400 to the price since they filled the tires with Nitrogen. He said that since nitrogen is inert, it doesn't eat away at the tire wall. Thats a load of BS, I bet he doesnt even know what inert means. Sounds like a f***ing scam to me. I dont see the outside of my tire being eating away by the air...
    I can understand if they use it in tires for high performance cars, but a used 2003 Pilot and charging $400 for it is retarded!!
    2020 Subaru Forester Sport
    I had nitrogen in my old car, but had new tires and rims on it and in 2 years it never leaked any air. Thats the only benefit I can see is that it doesn't leak as much since the molecules are bigger then air
    Oct 2006
    YYC/YYZ
    whoopdeefuckingdoo.
    Nitrogen covalent bond length = 75pm
    Oxygen covalent bond length = 73pm
    Oct 2007
    TX
    Camaro 2SS
    Originally posted by suen17
    whoopdeefuckingdoo.
    Molecular size of oxygen (O2): 0.29nm
    Molecular Size of nitrogen (N2): 0.31nm
    Although the permeabilities for each molecule through rubber could be different... but size wouldn't have anything to do with it...
    And its been mentioned that air is 79% nitrogen anyways. Dealerships really need to be taken to task for trying to sell someone nitrogen for $400, because even if it is effective and desirable to put in your tires (something I'm skeptical about) it's dirt cheap anyways. The dealership should be charging cents for this, not hundreds of dollars. All they are doing is preying in naive people.
    Apr 2006
    2008 Nissan Altima
    if i remember correcty (correct me if i am wrong) but back in high school i believe they tought us that aluminum and nitrogen react
    Originally posted by WongYue
    10% of a litre bike throttle should mean a 100cc right? I think I can handle that.
    Oct 2007
    TX
    Camaro 2SS
    mmm... not sure about that. You might be thinking of nitric acid, which is a completely different substance than molecular nitrogen.
    Aluminum reacts readily with oxygen though, the reason that aluminum doesn't "rust" is that all exposed aluminum surfaces quickly form a layer of aluminum oxide. Aluminum oxide is a rather hard material that remains readily bonded to the underlying aluminum surface, forming a natural sealant that prevents the material from oxidizing further and making it resistant to weathering.
    http://en.wikipedia.org/wiki/Aluminum_oxide#Properties
    This is in contrast to iron oxide, which as we all know, is a material that is substantially weaker than pure iron and readily flakes off from its substrate, leading to the destruction of the material.
    Apr 2004
    ////M
    I would pay 400 bucks just to rock the green valve stem caps
    Apr 2006
    2008 Nissan Altima
    I stand corrected
    Dec 2006
    SRT Charger
    Nitrogen filled tires maintain their air pressure due to the lack of water vapor. Its water vapor that causes your tires to loose or gain pressure due to fluctuations in weather (heat - cold).
    That said, a properly maintained compressor will not have much H2O in it, and will work just as good (for anything but all out race cars where 1/100 second is the difference between 1st and 2nd)
    Water vapor is also the biggest cause of leaky rims in that it causes the corrosion that keeps the tires from sealing properly.
    I would also like to point out the advantages, since this thread is getting pretty long...
    1. low fluctuations in tire pressure throughout all seasons
    2. reduced temperature within the tire and therefore reduce temp on tires, reducing wear
    3. inert and should reduce oxidization on rims.
    4. JDM, lol, might as well
    Thanks guys
    Mar 2007
    well i work in the aircraft industry and we use nitrogen in our tires mainly because of water vapors as 510-Trevor stated, no trace water vapors in aircraft tires can be allowed for the main reason that, when your 36000 ft in the air its about -52, the vapors will freeze and settle in the bottom of the tire, which will cause a wheel skid, which means, a delay in flight because there is a big hole in the tire.. so basically what i am saying is, nitrogen in car tires is a was of your money.
  1. Nitrogen in tires
    By TACO.VIDAL in forum General Car/Bike Talk
    Latest Threads: 03-04-2008, 08:43 PM
  2. FS: Joe Rocket Nitrogen Gloves SZ L
    By Go4Long in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-10-2008, 02:13 PM
  3. Nitrogen Filled Tires
    By soupey in forum General Car/Bike Talk
    Latest Threads: 11-22-2006, 01:28 AM
  4. FS: 2 18" tires and 2" 17 inch tires, also 2 16" tires
    By SpoonEK9@STRD in forum Automotive Parts [Wheels/Tires]
    Latest Threads: 04-24-2005, 07:00 PM
  5. Anybody use nitrogen in their tires?
    By CalgaryB5 in forum Performance Modifications
    Latest Threads: 07-04-2004, 12:48 AM
