09 Kia Rio: Dashboard not lighting up
Hey guys, the wife drives an 09 Kia Rio. Recently I changed some of the lights to LEDs. A couple didn't work out so I switched them back to regular bulbs (tail lights blew fuses, parking lights just didnt work). Replaced the blown fuses.
The dome lights and reverse lights are still LED and work fine.
After this I noticed the dashboard wasn't lighting up. Gauge clusters, stereo controls (stereo display illuminates still), and console shifter.
Fuse for cluster is good. All other fuses in vehicle are good.
Car has a remote starter, when used to start vehicle the dash does light up. Which tells me all the lights and fuses associated do in fact work.... Put keys in, turn to run, stays light. Hit break pedal, dash turns off.
Other minor issue: when starting with remote starter, or locking/unlocking, the tail lights and parking lights used to flash. Now only the passenger side does. Both tail lights work once the key is in the ignition though.
Problem with the starter maybe? Burnt ground wire somewhere? I'm lost.
EDIT: all lights have been changed back to normal. LEDs removed. Problem still exists.
I can eat more hot wings than you.
