Where to build custom 4awg wire? - Beyond.ca - Car Forums
Results 1 to 19 of 19
Thread: Where to build custom 4awg wire?
    Mar 2015
    Toyota’s
    Default Where to build custom 4awg wire?
    I know I know every post I put in this sub is "where do I find X", last one I swear
    I need to build 4 pieces of 4 gauge wire with some #10 and 1/4" eye connectors so I can install a fuse block/relay/breaker for the truck.
    Some guys have just used amp kits but that seems like a waste since I don't need all that speaker wire and stuff. Visions maybe?
    Jul 2007
    Blue boy
    Welding wire from Princess Auto
    Feb 2008
    teslo murdel free
    Autotemp sells it by the foot
    Dec 2005
    Sorrow
    Hatred
    Princess Auto welding wire FTW.
    -U
    Rage2
    battery places can make it, my buddy works for
    https://www.cdnrg.com/
    and he says they make em for customers.
    On the note of princess auto welding wire, i went there to get some one time and they were sold out, so i bought a pair of 4awg booster cables, ended up being half the price and got 2 pair of clamps for another project
    User title molested by Rage2.
    Visions does sell power wire by the foot, and their install shop should also be able to sell you whatever connectors you need.
    Mar 2015
    Toyota’s
    I was actually thinking about using some booster cables. A CB radio is going to be coming off the fuse block so I want to make sure I get as clean power as possible which I'm told means grounding the fuse block where the battery grounds. Not sure its worth buying another 15 feet of cable just for that though (battery -> cab -> fuse block -> battery ground)
    Mar 2011
    15 4runner
    Can you share where you found 4G ring connectors? thanks
    Rage2
    i get mine from eaby, way cheap
    they're called wire lugs
    http://www.ebay.ca/sch/i.html?_odkw=...g+lug&_sacat=0
    EECOL Electric here in Calgary will have them.
    If all you're powering is a CB radio 4AWG is likely overkill. Have yet to run into a CB radio that draws >100 Amps.
    I think going 4awg just to ensure clean power is also overkill, maybe a gauge higher than what you need and just ensure your connections are all good. Come to think of it, you probably don't have to do anything special at all other than good connections as they'll most likely be the source of any power problems you may have.
    Will fuck off, again.
    Mar 2015
    Toyota’s
    It's actually for a fuse block, the CB radio is just one of the accessories plugged into there.
    I ended up getting my cable from some small car audio shop in the NE. Visions only has amp kits apparently so they couldn't do anything, and Princess Auto had battery cable but no connectors.
    Mar 2011
    15 4runner
    Thanks for the leads, all I found initially on ebay/Amazon had $20 shipping..and no luck at Princess Auto or Visions. I did get 4 AWG stranded welding wire from PA. Putting in a 100A Blue Sea fuse block ignition switched similar to OP.
    Mar 2015
    Toyota’s
    Hah, that's exactly what I did
    Edit: I'm OP....
    Let me know if you find any quality relays, I'd bought a 100A 12V relay off amazon from China for 10 bucks but it doesn't work. The more I thought about it the less comfortable I was with using a cheap chinese knockoff that could potentially have 100A flowing through it too, so something that's less likely to burn the truck down would be ideal.
    Rage2
    Edit: I'm OP....
    you should have it fused anyway, a relay wont be the cause or savior of your truck the fuse will.
    Mar 2015
    Toyota’s
    Yeah I've got a 100A breaker right after the battery, then the cables come into the truck where I had a relay and then the fuse block. But the relay wouldn't close the circuit so I ended up having to just bypass it.
    Oct 2015
    06 Frontier/08 Versys 650/13 Versys 1K/06 CRF450X
    Edit: I'm OP....
    You're wanting to put your entire fuse panel on a relay?
    In my opinion you're better off just hooking your fuse panel directly to the battery and putting each individual load through a 30A relay. If you really want an ignition switched fuse panel I would pull a second one off the 100A panel and put it through a 30 or 40A ignition switched relay.
    Are you mounting under the hood or in the cab? I opted to mount a 100A Blue Sea panel under the hood. I figure most of my loads will be exterior accessories and I don't want to pull a bunch of bigger wires through the firewall. If I decide to add more stuff to the interior I might put a 30A panel in the cab.
    Apr 2005
    junk
    Greggs
  1. Replies: 87
  2. wire color code wire sterio
    By Subwoofah in forum Mechanical
    Latest Threads: 09-04-2008, 09:16 AM
  3. FS: Complete 4AWG Quality Kit - BRAND NEW - 55$
    By BoxsterBoy in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 10-02-2005, 03:46 PM
  4. FS: 4AWG Wire & Accessories
    By rinny in forum Automotive Parts [Audio/Video/Radar Systems]
    Latest Threads: 04-09-2005, 02:17 PM
  5. power wire vs ground wire
    By JC522 in forum In Car Entertainment / Electronics
    Latest Threads: 04-05-2005, 02:40 AM
