I've had some water pressure issues with one my zones that have been a little finicky since day one. The issue is on and off and it does build enough pressure most times (about 90%). The past few waterings, it's been about 60% reliable. First thought would be a leak. But I'm sure a leak would result in a consistent failure, but I could be wrong.
The sprinkler heads in one zone don't pop up entirely and dribble for about 10-15 seconds to a minute before popping all the way up for a full spray. Lately the heads have been taking longer to pop up (2 minutes roughly) and today, the heads didn't pop up fully at all when the timer went (around 6am if that matters).
So right before I left work, I manually turned it on and it popped up after a couple minutes. Then I shut it off for a bit and turned it on again and waited, and they didn't pop up fully this time.
Side note: When I turn on the system and heads begin to partially pop up, one thing that does help, is if I press one of the sprinkler heads back down to create more pressure, all the heads pop up immediately. It also didn't matter which one I pressed down.
Any help would be great.
