Slow shutdown with Windows XP SP2 - Beyond.ca - Car Forums
Results 1 to 20 of 22
Thread: Slow shutdown with Windows XP SP2
    Jul 2005
    Lethbridge
    2008 Saturn Astra, 1979 Honda CX500
    Default Slow shutdown with Windows XP SP2
    Hey guys, my laptop has been getting less and less enjoyable to use as of late. I'll give you the specs if that will help.
    Toshiba Laptop, Intel Celeron (yeah not great I know). 1.33 gHz, 128 mb RAM, 30 gb HD (with about 7 gb free), running Win XP w/ SP2. Regular Spyware scans (SpyBot S&D), antivirus (AVG Free), Firewalled (router and Win XP Firewall). System resources should be ok, I'm running minimal programs in the sys tray.
    The main problem is that whenever I go to shut the PC down, it takes forever. I click on "Start - Turn off Computer" and from there it takes between 3 and 5 minutes (no joke) to simply load the box that gives you the options of "Turn off, Restart, Log off."
    From there, once selecting "Turn Off," the PC takes an additional 5-10 minutes to actually shutdown.
    Anyone have any ideas what I should check?
    oreo cookie
    a wrx.
    Fucked up driver yo.
    Vancouver
    Jul 2005
    Lethbridge
    Ok, I performed the steps in that Article, and my PC did not have the NVidia Driver. But the shutdown is still just as slow.
    What driver would be causing this GTS Jeff?
    Mar 2005
    STi
    watch for the harddrive LED. if its solid then its a program shutting down slowly (most likely the antivirus). if there is no light then you should clean up the partition (defrag, disk cleanup, and download a program called: crap cleaner)
    give it a couple hard boots then it should be ok..
    Vancouver
    there's a certain line in the registry that deals w/ shutdowns, and specifically how long to wait before terminating applications
    if that doens't fix it than it's probably hardware, tho i don't know why it's only acting up during shutdown
    oreo cookie
    a wrx.
    I have no idea man, but I've experienced this sort of problem before many times. In my experience as an (uncertified haha) computer tech, these things are almost always caused by buggy drivers, whether they're default MS drivers or whether they're brand new releases that are untested. Some companies moreso than others are known for releasing resource hogging drivers...a few that I can name from my own experience:
    Creative, Logitech, Lexmark...
    I think the best thing you can do is try to remember when this problem started happening, then try and remember if it coincided with any driver updates or hardware changes. If you have no idea, just try updating all your drivers. If that doesn't do it, then you may be stuck with doing a fresh install of Windows. With the fresh install, install one driver at a time, restarting every time and making sure that the problem doesn't appear.
    Aug 2004
    C-Bill
    Pimp Mobile
    i cant wait until Windows Vista, XP has been nothing but a boat load of problems...blue screens here, slowing down to a crawl there...i thought it was just ME but most ppl on XP experience problems!?!??!
    Feb 2004
    i have this problem too!
    i was wondering what the hell was going on i kinda thought it was my overclock but i don't really see why...so im goin to try those steps and whatnot
    9.872604, -85.498802
    Turbos n Stuff™
    PEBKAC
    XP boots up and shuts down, crazy fast for myself, and most of the people I know. Rarely encounter any errors, the only errors I do encounter are hardware ones (motherboard and ram mainly, but HDD's being maltreated also)
    If you got tyhe computer loaded up w/ junk, it's not XP's fault.
    Travel
    Feb 2004
    i noticed this problem wasn't here till after i downloaded a nvidia driver for dvds but seeing this i did the steps now it shuts down faster than before!!! YEAH!!!
    lotsa cool tips inside too some i thought everyone should know but hey im just a nerd
    May 2004
    Calgary,AB
    Porsche 911 Cab
    I would agree with the faulty driver, I had the same issue with an older non-compaitble Roxio driver. Had to remove the drivers and edit the registry to not load them anymore.
    Vancouver
    Originally posted by Ben
    PEBKAC
    Jul 2005
    Lethbridge
    Yeah it's not loaded with junk, don't have any p2p software, no games, it's used just for school and surfing...
    ah well, I can live with it, its just annoying.
    Turbos n Stuff™
    Well it's something then, because I install WinXP SP2 on a weekly basis and manage a few dosen users on it, and none have this problem, fresh installs or well used.
    Travel
    Sep 2002
    PEBKAC
    Yup, everyone tries to blame hardware most of the time. Most errors or slow downs that I find are user caused or user aggro'd.
    I have personally never had an issue with XP on either my personal laptop, work laptop, home desktop or media center box...
    Jul 2005
    Lethbridge
    Well I'm not trying to sound almighty and say that I have no part in it whatsoever. I don't know enough about computers to say that. Just don't have it loaded up with junk...
    Turbos n Stuff™
    hmmmm...well, I'll take your word for it bro, but something is not right for it to take 5 minutes. 1 or 2...MAYBE, but it sounds like a process wont shut down.
    As mentioned above, it could be an antivirus prog, or a drive, or a peice of spyware that you didn't know about..
    If you open "regedit" (start, run, type "regedit")
    HKEY_CURRENT_USER > Software > Microsoft > Windows > CurrentVersion > Run.
    What is listed in there?
    Have you tried the other regedit about "WaitToKill"?
    Travel
    Feb 2004
    for me it was a nvidia decoder!
    Edmonton
    looking 4 one
    I'll bet it is the anti virus that make you wait for a 30 second time out
  1. FS: Greddy SP2 Exhaust for 92-95 Civic H/B
    By WBB6 in forum Tunerworks Performance Auto House
    Latest Threads: 08-14-2006, 12:46 AM
  2. fs: greddy sp2 exhaust
    By _integra_typeR_ in forum Automotive Parts [Mechanical Parts]
    Latest Threads: 09-28-2005, 09:13 PM
  3. anyone done the win xp sp2 install yet?
    By danno567 in forum Computers, Consoles, and other Electronics
    Latest Threads: 08-18-2004, 10:05 AM
  4. Rx8 with Greddy SP2 Catback exhaust system
    By david394 in forum Cars, Bikes, Machines
    Latest Threads: 05-27-2004, 11:22 PM
  5. WinXP shutdown/standby/? question
    By kaput in forum Computers, Consoles, and other Electronics
    Latest Threads: 04-08-2004, 05:57 PM
