Kincora, Evanston and Sage Hill - Beyond.ca - Car Forums
Page 1 of 4 1 2 ... LastLast
Results 1 to 20 of 65
Thread: Kincora, Evanston and Sage Hill
    Nov 2005
    A Slow Car
    Default Kincora, Evanston and Sage Hill
    Between the 3 communities, which one has the most expensive homes? I did notice that Kincora does not have a 3 car garage homes. I talked to my Brother in law who lives in Kincora obviously said Kincora has more expensive homes then Evanston and sage hill.
    “Straight roads are for fast cars, turns are for fast drivers.”
    Grimace
    I think each of the three have a range of homes from $ to $$$. Probably Kincora has nicer ones ($$$) but then sage hill for example has houses backing onto the natural area which are like ~$700k iirc?
    Evanston is about the same though but then there is also evansridge, sage meadows and nolan hill in those areas also.
    Jun 2003
    Toyota Sequoia
    Default Re: Kincora, Evanston and Sage Hill
    On average, Kincora should be more expensive than the other two communities.
    Apr 2005
    CALGARY
    Kincora
    Jul 2007
    NW Calgary
    Lexus/Toyota
    I won't comment on which area is most expensive, but Kincora does have 3-car garage homes. I have seen several, including my next door neighbour.
    Oh and Kincora has ravine lots as well, my walkout house backs onto one. Although I believe Sage Hill and certain parts of Evanston (Evansridge) has greenspaces they back onto as well.
    Nov 2005
    A Slow Car
    Where abouts?
    Apr 2003
    F10M/F87/NA2/W220/V90/E46ZHP/SE3P/DC2
    there are three car garage houses in Evanston iirc. But if you are gonna spend that much, why limit yourself to those three communities.
    Jul 2007
    NW Calgary
    Lexus/Toyota
    Where abouts?
    Off the top of my head I have seen the three car garage wide houses on Kincora Point and Kincora Bay. There are a lot of others that have the a double with an extra tandem stall to make it a triple.
    Jul 2011
    on average Kincora....pretty hard to get into the neighbourhood for under $400K where as evanston and sage hill have entry level homes available in the $300's....that being said I think Evansridge has some very pricey homes along the ridge in the $700+ range
    Sep 2005
    2011 lexus is250 awd
    Why are you concerned with which area has the more expensive homes? If you are shopping for one in the area, it should be based on your personal taste, not based on price. I'm in Sage Hill and I chose it because I got a lot across the street from a park.
    Just my 2 cents
    Mar 2011
    GP
    4Runner
    Default Re: Re: Kincora, Evanston and Sage Hill
    Just my 2 cents
    This. Kincora is the most established of these three communities right now, so it makes sense the homes would be more expensive. Both Evanston and Sage Hill are building new shopping centres, and Evanston two new schools. Once this work is complete I would expect homes to be quite comparable (Evanston possibly a bump due to presence of schools).
    Nov 2005
    A Slow Car
    Just my 2 cents
    I know two people that live in Kincora told me that you can't compare Kincora to Sage hill and Evanston. I am curious why they're saying that. All 3 communities have acres of greenspace, future school site, playgrounds and walking paths. So why is Kincora a better area?
    Jan 2003
    Of the 3, I prefer Kincora because it's slightly older and closer to downtown. I think most homes in Kinora are around $500k, where in Sage Hill and Evanston, you can find homes around $300k-$400k.
    Sep 2002
    CGY
    Cayman, F150, Crosstour
    From what I remember (and my opinion) Evanston has higher end homes on the Ridge with Triple garages, but also has a bunch of homes with detached garages and back alleys - quite the mix. Some detached triples also
    Sage Hill always had slightly lower price point than Kincora, and there Nolan was lower still initially.
    Also Sherwood is also similar to Kincora and pricing generally falls in line with it. Several triple garages in Sherwood though.
    All are fairly similar when it comes down to it and have similar access.
    Jun 2005
    Default Re: Re: Re: Kincora, Evanston and Sage Hill
    They're just saying it because they live there
    They don't want to say they live in a "worse" area
    Mar 2011
    GP
    4Runner
    Kincora would be very slightly closer to downtown than Evanston, if at all (Evanston is immediately east, across Symons Valley Road). I do like that it is more established though.
    Sherwood was brought up, I think that it would be a step above all of these communities in house prices/sizes.
    Sep 2005
    In all 3 areas your going to see homes in the 399 range as well as homes in the 700k range.
    I've seen homes in Kincora go for $400 just as much as I've seen homes in Evanston/Sage Hill for $400. There's always going to be the person who just doesn't care about upgrades and go with base specs when they build the home.
    Kincora being the oldest community of the 3 may be a little more developed so prices might be ~5% higher but I can see Sage and Evanston catching up after a few years
    Jun 2003
    Toyota Sequoia
    Yeah. As mentioned, there isn't that much of a difference but Kincora presently will have a slight advantage overall in value due to it being more established. The nicer exterior stone finishing on every house in the community does make it feel a bit more upscale and uniform to me, but whether that increases value for someone is quite subjective.
    Commute was horrible today.. I hate living in Evanston !
    Aug 2008
    TDi
    Normal time to get to look from Sage = 15mins
    Today = 30 mins
    GO FLAMES GO!
  1. Kincora/Evanston etc
    By bigbadboss101 in forum Real Estate / Finance
    Latest Threads: 11-23-2018, 07:41 PM
  2. Sage Hill/Symons Gate/Nolan Hill/Evanston...Etc
    By ickyflex in forum Real Estate / Finance
    Latest Threads: 08-26-2017, 10:15 AM
  3. Investing in a property in sage hill, kincora, nolan hill, etc
    By nagooro in forum Real Estate / Finance
    Latest Threads: 10-08-2015, 05:31 PM
  4. Sage Hill - Sage Stone Townhomes
    By CalgaryXXL in forum Real Estate / Finance
    Latest Threads: 03-12-2013, 12:05 PM
  5. F.S. House in Sage Hill great deal!
    By 2.2vtec in forum Real Estate / Finance
    Latest Threads: 10-15-2008, 12:50 PM
