B6 1.8t Audi A4's, any good? - Beyond.ca - Car Forums
Results 1 to 14 of 14
Thread: B6 1.8t Audi A4's, any good?
    ___________________________
    Default B6 1.8t Audi A4's, any good?
    I know there are some Audi guys on the board so I wanted to ask the questions, are the 1.8T 2004- 2005 b6 a4's any good? I have a an mk4 jetta wagon 1.8t that I've been thinking of replacing but I'm not sure if it's worth giving up for the Audi.
    Red Deer, AB
    PSG / LA
    B5 S4, UrQ, UZJ100, 990 SMR
    Similar motor, the later 1.8T's aren't ideal for modding (weaker internals). 99.5 has the best 1.8T block.
    I have a 2002 A4 1.8T Avant 5SPD that needs some work but could make a great beater. $2k and it's yours!
    B6 common issues:
    Foggy headlights
    1.8T can get sludging issues if proper spec oil and intervals aren't used
    Fair fuel economy for a heavy AWD (9-10l/100km city, 7l/100km hwy)
    Acceptable power with chip and downpipe
    More convenient than a sedan, but really look at C5/C6 Avants if you want cargo space
    AWD is bulletproof, but keep in mind 4 axles to services cv boots on instead of 2.
    Common high mileage issues:
    leaky diff seals, cracking cv boots, worn and tired bushings, exhaust leaks, door blade rust, worn inner fender liners.
    Last of the 5V/Cyl motors!
    Originally posted by InRich
    tell her I'll pick her up in the vette
    The X5 i bought earlier this year really is FULLY LOADED though not a single option missing including infrared night driving
    Oct 2006
    oooo
    Mine's been fantastic but I've owned it since new. If the car hasn't been well maintained I wouldn't even consider it.
    That being said no matter what you do if you look at one have George at TuneDub take a look at it before you spend any cash.
    2017 VW Jetta 1.4T (winter car)
    2010 F-350 Nortruck Tool Shed
    2007 BMW 5 (Wifey's)
    2004 Audi A4 1.8T 6spd Stage III w/ Meth
    1985 F-250 6.9L IDI w/ATS turbo
    that's awesome thank you've had it since new, post some pics!
    zipdoa, you have pm!
    Red Deer, AB
    calgary AB
    toyota MR2
    haha I was going to post a similar thread for a friend.
    May 2014
    Pt Cruiser
    B6 common issues:
    Foggy headlights
    I really want to do a big turbo on one of these...
    $1500?
    PSG / LA
    $1500?
    Lowballs accepted in person only PM me.
    Jun 2007
    Calgary/Alberta
    I know over the years I have read how much sillysod liked his. My brother had totally different luck and one wonders why he owned three (2002/2003/2004). He bought and had them all in the range of about 80-120k kms. 1.8T automatics also.
    2 of 3 - steering column went 100k and 110k ($3k repair).
    3 of 3 - timing belt went between 105-115k
    2 of 3 - transmission went 100k and 115k
    2 of 3 - a front heated seat malfunctioned, he didn't replace cause of the cost audi quoted
    1 of 3 - headlights malfunctioned and had to be replaced - 110k
    On the flip side an Engg friend had a 2004 manual with 230k kms and his repair bill was insanely low.
    It is frustrating because it was a nice solid car to drive. Good pep stock, decent fuel efficiency and all around nice car. His 03 was chipped and that was a noticeable kick in speed which was fun.
    Just make sure any car you buy if you're going to spend much take it to tunedub to check some of the above issues out. They can be quite scary if you're unlucky
    PSG / LA
    Curious about these two incidents. What happened with the steering column? It wasn't the steering rack that failed, was it?
    Timing belts - Did his fail and ruin the head?
    Jun 2007
    Calgary/Alberta
    Zip.
    For the steering column the one had a leak that wasn't detected and went super fast. He was driving home from Quarry Park and could barely steer so pulled into glenmore. Told him column/rack went. Bill was $3300.
    Second time he was aware after the first bill. His steering got stiff so I grabbed him fluid to fill up. Was fine for a few weeks then one morning went to start his car and couldn't steer. The fluid wasn't properly going to the rack and had seized up. Same nasty bill.
    All three timing belts he could hear because he was driving and it was slipping/making a super loud noise. The first time he asked me to check what the noise would be and I had a feeling thats what it was. So drove to Audi and sure enough had to replace so thankfully no damage but the bill IIRC was between 2500-3000. So after that on the 2nd/3rd cars he knew the sound and immediately stopped driving car and took to Audi to prevent any disasters.
    But like I said, he had some pretty bad luck with all three of his. He currently has an 08 A4 2.0T it is sitting at just under 140K without any issues since purchase at 60K.
    May 2009
    G37X
    Zip.
    I've gotta ask, after 3 experiences like that why did he buy another A4?
    Jun 2007
    Calgary/Alberta
    Didn't say he was very bright, he loved how the car drived and wanted an A4 really bad. Only reason he turned out not bad was they all got written off for a large chunk more than he paid to offset bills.
    But I know it prevented both my parents from buying Audi products the last 2 vehicles. They went with BMW/Benz to avoid.
    Jul 2005
    MK7 R
    I had a 2004 B6 A4 sedan with Unitronic stage 1+ and downpipe. I loved that car until someone rear ended it and was totaled.
    Problems I had with it:
    -Had a coolant leak and needed one of the flanges replaced.
    -Heater stopped working. Heater core needed to be flushed.
    -Kept getting error codes about the MAF, needed to be replaced.
    Tunedub took care of all issues and also my maintenance. Great shop.
    Also like zipdoa said above, mine also started having rust on the door blades and the fender liners were starting to wear out. Both were easily remedied but I never bothered as I considered them cosmetic and the car still ran great.
    Oct 2002
    E90 335xi, ZX-10R
    I just picked up a B7 A4 and while I know it's not exactly the same car, it is pretty similar to the B6. I went from an MR2 to this and I love it! I got it chipped right away at Tunedub with a Unitronic Stage 1+ and it really woke it up. Pulls about the same or harder than my MR2 did. And way smoother both in power delivery and overall driving experience.
    The build quality is great, but I guess you'll already have some pretty decent quality in your Jetta. And if you're happy with your Jetta, you may not find it a big upgrade going to the A4. Although the AWD is definitely nice to have.
  1. looking for a good massage therapist... any good recommandation
    By tktwhiz in forum Sports, Health & Fitness
    Latest Threads: 04-24-2015, 04:59 PM
  2. Audi A4 vs Audi S4 vs Audi URS4
    By HiTempguy1 in forum General Car/Bike Talk
    Latest Threads: 01-09-2014, 11:25 PM
  3. Replies: 0
    Latest Threads: 12-31-2009, 01:40 AM
  4. Audi RS4 vs classic Audi Quattro
    Latest Threads: 12-22-2006, 01:01 PM
  5. Want to buy an RC car, any good websites? Any recomendations?
    By Redlyne_mr2 in forum Computers, Consoles, and other Electronics
    Latest Threads: 07-28-2005, 05:06 AM
