Its runs a supercharged 6.2-liter V8 cranking out an estimated 640 horsepower and 640 pound-feet of torque. Codenamed LT4, you know this engine from the Corvette Z06. That power allows the 2017 ZL1 to outgun the '15 model by 60 hp and 84 lb-ft. "This is the hammer in the Camaro lineup for Gen Six," Reuss said. It will go on sale late this year.
All of that power will be hooked to GM's first use of its long-awaited 10-speed automatic transmission with paddle shifters, which is tuned for the prodigious output of the ZL1. More significantly, the gearbox will be in eight vehicles by the end of 2018. Enthusiasts, rest assured: the ZL1 will also offer a standard six-speed manual transmission with rev matching.
The powertrain is the attention-getter, but the chassis is also tuned for performance. It has a Magnetic Ride suspension, an electronic limited-slip differential, and performance traction management. It rolls on 20-inch forged aluminum wheels wrapped in Goodyear Eagle F1 Supercar tires with a special compound developed for this car. Stopping comes from six-piston Brembos with two-piece rotors.
The exterior design is all about aerodynamics, and a larger lower grille provides more airflow than the one on the SS. There's also Chevy's "flow-tie" badge, which is simply a cutout of the iconic Bow Tie to let more air pass through. Chevy also added a new hood with a carbon-fiber insert, a larger front splitter, and a wing in back. Wider fenders and unique rocker panels punctuate the look. The cabin has Recaro seats, a suede flat-bottom steering wheel, and an optional Performance Data Recorder. Other nifty features include
11 heat exchangers to cool the powertrain, a drive-mode selector, and dual-mode exhaust.
