Does the mini 0806 use the same base as the 0803?Originally posted by Calgaryscot
I had a mini 0803 with GPS installed in the front for a couple of years and decided to upgrade to a front/rear set up, tried the K1S first, was ok but no sound so I sent it back, then tried the Thinkware dual cam, good quality but the only memory cards that will work are their own brand and they are very expensive.
In the end, I moved my 0803 to the rear, I have tint but you can up the E/V to compensate and I bought the newer mini 0806 for the front.
Both are excellent quality and very discreet, the base stays on the glass and the camera just slides in and out if you want to take them off when parked.
Hardwiring is easy, buy the hardwire kit from Amazon for $15 and then just use a fuse tap, the cameras now switch on and off with my ignition.
Google "Techmoan" he gives great reviews on dashcams :-)
In the end, very happy I stuck with the Mini series.
