Radon? - Beyond.ca - Car Forums
Page 1 of 10 1 2 ... LastLast
Results 1 to 20 of 188
Thread: Radon?
    Jan 2013
    2014 Lexus IS250
    Default Radon?
    Lots about it on the news these days.
    Has anyone actually tested? If so please share your results and neighbourhood.
    I'm testing right now but it's a long term testing kit (3 months) up in West Springs
    Sep 2012
    Neighbourhood wouldn't tell much
    Some times 1 house has high levels, next door it is normal
    Mar 2009
    '18 Murano
    Got one of those mail-in test kits from Home Depot.
    Came back at 108Bq/m3. Under the recommended max. I may do another test in the future.
    May 2003
    WRX, Audi A4 Avant
    Ordered a test kit on amazon a few weeks ago... I think another 4/5 months before I send it in. The longer the better the reading apparently
    Cochrane, AB
    Trucks
    New homes should be tested to pass the final building permit inspection.
    Jun 2003
    2009 Impreza
    Had a 3-month test done as part of the UofC study about a year ago. Results came in at about 175 Bq/m3.
    Okotoks North
    My house was 123 +/- 16 Bq/m3
    It's such a cheap fix for radon mitigation I wonder when it will become standard for all new homes in the area. I think it's only $2000 after the fact, and probably $250-300 if done during the build.
    Bunch of Honda's
    The latest building code requires that the under slab ventilation (basically gravel & capped pipe in basement) is required. So the ‘rough in’ in mandatory but the ventilation to the exterior is not.
    So it's just a vent from below your basement slob to the outside air? Is that right?
    Wonder if a house with weeping tile and sump pump is better or worse?
    Sep 2005
    My last house was as in the 300's and my current house was in the 400-500 range.
    I bought this for a detector: https://www.amazon.ca/Safety-Siren-H...keywords=radon
    I had quotes from Radon West and Radon Controls and went with Radon Controls. I found it was still expensive despite being roughed in since I'm in a new build. I even supplied my own fan that I bought for the old house. Paid $1470 with Radon Controls and Radon West wanted $2k still.
    I am currently sitting at 29 Bq/m3.
    Fear generation is high with this.
    "You're breathing Hydrogen into your lungs". That would generate fear in people too.
    It's called running a fan, furnace cold air sources help and opening basement windows in the summer.
    You'll all live.
    http://www.inspection-perfection.com...l#.WOO1_TjnZQs
    Jan 2013
    2014 Lexus IS250
    Thanks. Did they vent out the basement all the way up to the roof or just out the side wall?
    Sep 2005
    Both Radon West and Radon Controls do side wall only. Radon West quoted something like 80% dissipation within 5 feet once vented. Radon Controls looked at the install on my neighbors house and said Radon West's vent was too close to the basement window so they seem to follow stricter guidelines.
    Sep 2005
    You'll all live.
    One of the first things I tried was to run the furnace fan and my levels never got under the acceptable limit on my old house.
    I then tried to install a timer on the basement bathroom fan and ran that to exhaust 8hrs a day. This actually made the problem worse by creating a vacuum that sucked more radon in lol.
    Cochrane, AB
    Trucks
    Do homes not have a vapour barrier under the slab like commercial buildings do? I don't see where gas is seeping into the house.
    Bunch of Honda's
    They do but it'll have a 1000 puncture holes in it and not be sealed at the perimeter or any pipe penetrations.
    Mar 2015
    Lethbridge AB
    1994 Mustang, 2007 F150, 1991 Volvo 240 Wagon
    Every time I hear radon I think of this:
    Michael: Toby has been leaving radon kits everywhere, like he owns the place. The first time I threw mine away, I thought it was an ant trap. [finds radon kit in between his blinds in his office] But I figured I'd rather live with ants than with his creepy little disc. [throws it away] The second time... I thought it was one of those, you know, those things you turn over and it moos. [finds another radon kit on top of his cabinet] Like a cow thing. But upon closer examination, it was another ant trap, so I threw it away. And the third time... I did it out of spite. [takes radon kit from the top of the blinds of his office window and slams it into the trash can]
    1994 Mustang - SBF swap in progress
    Dec 2008
    Lots of fear mongering around this lately. Any real truth? The research posted on the EPA site looks pretty misleading in terms of conclusions based on the poorly controlled datasets
    Jul 2008
    Pallet Town
    Meh, its just a little radiation. Gives a nice healthy glow.
    Cocoa $10,000 per tonne.
    Okotoks North
    Probably being oversold a bit by companies that are into mitigation.
    However, if done early as part of the build process now that rough-in is code there wouldn't be much cost (fan and pipe to exterior). Even after the fact without the rough in is about $2000... some people will probably spend close to that over 20 years on useless filtrete filters.
