My Veloster is throwing codes about cylinder misfires. - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 44
Thread: My Veloster is throwing codes about cylinder misfires.
    Nov 2005
    2015 Hyundai Veloster
    Default My Veloster is throwing codes about cylinder misfires.
    A few weeks ago I had work done for a purge leak somewhere on the top end of my engine, it was done at the Hyundai dealershipand everything has been great since. Until today, I was driving home and my engine light came on again so I pulled these codes. Any idea what's causing it or does it have to go back to the mechanic again?
    - - - Updated - - -
    Originally posted by Go4Long
    Originally posted by blitz
    Mar Buddy I missed you!
    Sep 2008
    Turbo stuff
    Check plugs is the first thing I do with any car throwing misfire codes. Apart from that, if it's turboed, check for boost leaks, make sure your fuel quality is good, blah blah. Could be a ton of things causing misfires but start there. How many km on it?
    6.7 CUMMINS, E50 AMG
    Do you get these codes soon after you start from cold, rather than warm? The diagnostics screenshot looks like it was taken shortly after a cold start. If you cleared the codes after warmup and some driving will the same codes pop up?
    Sep 2008
    Turbo stuff
    Tldr: needs an engine
    Nov 2005
    Quote Originally Posted by Sentry View Post
    It is turbo and my OBD reader was showing 15 pounds of boost consistently when on the throttle. This is also its first tank of 87 octane, it had always had 89 but Shell dropped their 89 to replace it with 93 so I had to step down to 87 which is what the manual suggests.
    Quote Originally Posted by legendboy View Post
    I drove it home from work, the engine code popped up while on the way but my OBD reader won't read codes while the engine is running. After I got home, I shut off the engine, then immediately turned it back to ACC so I could read these codes. The engine isn't actually running here, I don't know why it's showing RPM.
    Feb 2003
    DT 780
    LEXUS LX470
    Quote Originally Posted by Mar View Post
    This is also its first tank of 87 octane.
    /thread
    Tap, Rack, BANG!
    Wait, so your obd reader is also clearly broken?
    Marachino_cherry_dot_gif
    Engine day?
    That's tomorrow.
    Nov 2005
    I've always gotten an error on my phone telling me it could damage the system if I try and read the codes while the engine is running. It suggest I turn the engine to ACC and then it doesn't give me the warning.
    The reader was $11 on Amazon and I use OBD Fusion which was $7 on Google Play.
    Sep 2008
    Turbo stuff
    Fill it with 93 or 94 and clear the codes, see if they come back.
    Just incredible.
    /thread
    Try this
    Nov 2021
    E46
    Freeze frame is saved data from when the trouble code was set. The P0300 set at 1401rpm. If you want live data you have to go into PID's.
    From the freeze frame data, I would be looking at carbon build up on the intake valves. And the dealer didn't fix the purge problem because a P0441 has set, a stuck open purge valve will cause misfires, but usually also set rich/lean codes.
    I don't think the 87 fuel is the problem.
    Nov 2005
    I missed the last part, it's 16X,XXX.
    Some good advice buried in here.
    Can we get back to fast n furious terms. Purge valve is the BOV?
    Anytime you get codes, read them, clear them and see what comes back. Don't drive the vehicle hard, see what comes up during normal, not abusive driving.
    Multiple cyl misfires is almost never the plugs, inj, etc.
    Aug 2011
    Strathmore
    2005 Dirtymax
    Purge valve is for emissions
    Some vehicles use a BOV some use a re-circulation valve (Subarus)
    But I would never run 87 in a boosted car.. shit fuel.. and can definitely cause issues.
    It was noticeably colder today.
    Frozen battery.
    Dec 2006
    Nothing worth mentioning.
    Frozen battery.
    Or……….somebody’s got a case of the Hyundais
  1. Russian Attack Choppers Misfires on Parked Cars
    By rage2 in forum Society / Law / Current Events / Politics
    Latest Threads: 09-19-2017, 03:10 PM
  2. 2005 F-150 throwing codes on its birthday
    By schurchill39 in forum General Car/Bike Talk
    Latest Threads: 09-17-2012, 04:26 PM
  3. Mythbusters: Cannon misfires.
    By ZenOps in forum Society / Law / Current Events / Politics
    Latest Threads: 12-07-2011, 06:51 PM
  4. 03 Denali throwing all 4 u2 sensor codes
    By becks101 in forum Mechanical
    Latest Threads: 10-18-2011, 10:57 PM
  5. 2012 Hyundai Veloster Spy Video
    Latest Threads: 05-28-2010, 02:20 AM
