Exploder - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 56
Thread: Exploder
    Sep 2008
    Turbo stuff
    Default Exploder
    2007 Explorer, 4.6 3v, 6spd auto. Gonna be the new do-everything daily. Everything includes going fast.
    Just picked it up in March, little rough.
    First order of business was a wheel and tire setup. Wanted to go down an inch on rim size and up two inches on tire diameter. I found these 17" wheels off a 06 Mustang GT. Mounted up some 32" Kumhos and they fit perfect. No rubbing, no spacers needed, no lift needed.
    Next up got a new grille for it. Decided to go with a straight bar grille instead of the side nostril Eddie Bauer one that was on it.
    And put in a double din android deck
    06 S2000
    I'd like to know more about the go-fast-bits, and any other future plans. Can't wait to see what you do.
    My car sounds like shit.
    Sep 2008
    Turbo stuff
    3 spoon engines with NOS
    #ExtraSlow
    #SidewallLyfe
    May 2008
    Mustang wheels really work on there!
    Sep 2008
    Turbo stuff
    The plan is something along these lines, straight through a water to air intercooler into the throttle.
    Sep 2008
    Turbo stuff
    Little tinkering today, wanted to get the turbo-intercooler-maf-throttle stack up correct since that'll set the final position of the turbo. As you could see in the above post I had a little too much length going on.
    I cut the silicone coupler back about 30mm and then cut the MAF housing back about another 30mm and welded it directly to the intercooler.
    Cochrane, AB
    Trucks
    Can you flip the manifolds on this one? The exhaust routing looks impossible in this pic.
    Sep 2008
    Turbo stuff
    Thats a problem for future me. I always find a way.
    Cochrane, AB
    Trucks
    Quote Originally Posted by Sentry View Post
    Yup. Probably look much easier once the wheel well liner takes a hike. Does it have struts like a car or is it a ladder frame?
    Sep 2008
    Turbo stuff
    Ladder frame but the shocks are super tight to the engine.
    Threw some Ferd Racing 52lb injectors in it. Engine bay gets dusty as shit, it's pretty wide open under and on the sides
    Sep 2008
    Turbo stuff
    Built hotside this weekend. Up next is downpipe and rest of the exhaust.
    Running the ol "turbo delete" plate for now until I do oil lines.
    Sep 2008
    Turbo stuff
    Finished my downpipe and exhaust last weekend, did oil lines today, and she's boosted!
    Only running 5psi non intercooled right now, final goal is 10psi with the intercooler obviously hooked up. Have to install a pump and lines and heat exchanger for it.
    Jul 2008
    Transnistria
    Exploded.
    mmmm turbo
    Sep 2008
    Turbo stuff
    Stupid plugs for my stupid Ford
    For some reason it was breaking up at a measly 5psi
    Cochrane, AB
    Trucks
    That’s just a pipe plug, not a spark plug.
    Sep 2008
    Turbo stuff
    Intercooler done! Mounted heat exchanger, pump, reservoir, and ran hoses. Man this thing rips.
    Aug 2011
    Strathmore
    2005 Dirtymax
    LOL. Who needs spark!
    2008 Z06
    I love the compact turbo to IC to intake setup.
    Mar 2006
    What management are you running to control the boost?
  1. Ford Exploder
    By Gripenfelter in forum Automotive News
    Latest Threads: 03-07-2006, 08:18 AM
  2. MS Exploder issue??
    By Ekliptix in forum Computers, Consoles, and other Electronics
    Latest Threads: 02-15-2006, 12:24 PM
