Hot Water Tank Replacement - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 50
Thread: Hot Water Tank Replacement
    Aug 2004
    Default Hot Water Tank Replacement
    Anyone done one lately...
    My 15 year old unit is starting to shown signs of kicking the bucket. Did another T-couple replacement this weekend.
    Anyone recently quoted / installed a 50 Gallon replacement ?
    Not interested in doing it myself or switching to tankless.
    Thanks.
    2011 Ram 1500 QC Sport
    2017 Jeep Cherokee Limited
    Apr 2006
    Cowtown
    10' 4Runner SR5
    You're looking at ~$1,500 if it's atmospheric (easily double if it's forced air).
    I used these guys, did a great job.
    https://www.primeplumbingandheating.ca/
    Ultracrepidarian
    Dec 2006
    Nothing worth mentioning.
    I got pete the plumber to do mine. Was like 1300 if I remember correctly. Was a couple years ago though.
    Jan 2017
    Summer car or work truck
    ^^same
    Mar 2009
    '18 Murano
    Quote Originally Posted by SJW View Post
    Same. Mrs. Penguin booked them. I was a bit skeptical cheesy commercials and all, but they did good work and were reasonably priced.
    Lariat
    Just replaced mine about a month ago, I think it was 50gl. Cost about $1,800 but it was an emergency replacement as mine went out and needed a new unit asap as it was during that deep freeze in jan.
    _____ASP______
    current ski quiver:
    park,all mtn: 181 Armada AR7
    big mtn, pow: 185 Armada JJ
    Feb 2003
    DT 780
    LEXUS LX470
    how often are people draining or replacing the rods on their tanks? I'm getting reddish buildup in my sink drains so wondering if rod is spent and tank is starting to rust??
    Tap, Rack, BANG!
    Only 15min from Aspen!
    Nothing interesting anymore
    I've replaced mine twice in 15 years. The real key to longevity though is regular tank draining. Just a few gallons forms the drain spout a few times a year gets rid of the mineral build-up.
    Mar 2007
    Edmonton area
    Has wheels
    3-5 years is recommended. Would be a good thing to check, replace and flush out your tank. It wouldn't hurt anything and you'd only be out the small cost of the anode rod.
    Good reminder I should do mine.
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Just hook up a short garden hose and let er rip down the floor drain?
    Ultracrepidarian
    Mar 2007
    Edmonton area
    Has wheels
    I've been meaning to do mine too.
    HOW TO FLUSH A WATER HEATER IN 7 STEPS
    Flushing your water heater can be a complex and sometimes intimidating process, but we’ve outlined 7 detailed steps to follow.
    STEP 1: TURN OFF THE WATER HEATER’S THERMOSTAT
    How to do this depends on what model you have. Check the manual for specifics, but here are some general tips:
    Look for an Off button toward the bottom of your water heater.
    If you’re dealing with an electric water heater, you’ll need to look for your home’s breaker box and turn off the switch that supplies power to the unit.
    If your model is older, you may need to relight the pilot light before being able to use the heater again.
    STEP 2: TURN OFF THE GAS SUPPLY
    This is a crucial step when you need to flush a gas water heater. The Off button should be located on the pipe leading to your thermometer. Once you switch that off, you’re good to move to step three.
    STEP 3: TURN OFF THE WATER SUPPLY
    Toward the top of your water heater, you’ll find a switch or valve handle that controls the cold water flow. Use it to turn off the cold water.
    STEP 4: TURN ON YOUR HOT WATER IN A TUB OR SINK
    Locate the faucet closest to the water heater and turn on the hot water. Doing so will drain your hot water and release the pressure from the tank.
    STEP 5: CONNECT THE DRAINAGE SPIGOT
    Unless you already have a hose connected to your hot water heater, you can use your garden hose for this step. Connect one end to the drainage spigot, and put the other in a secure place, like a large bucket or a bowl, where it can drain safely.
    STEP 6: TURN ON THE SPIGOT AND DRAIN
    Flushing a water heater requires a watchful eye. Once you turn on the spigot, keep an eye on the quality of the draining water. You won’t want to stop draining the heater until the water runs clear.
    If your water is discolored or has sediment coming out, your water heater certainly needs flushing. If you find your water isn’t clearing up, you may need to drain the water to clean it properly.
    STEP 7: FLUSH
    In order to flush your water heater, you’ll need to turn on the cold water spout and let it run for a few minutes. Keep a close eye on the water coming through the hose. Again, you’re watching for the water to run clear. Once it does, you’re all done with the flushing process.
    2020 Subaru Forester Sport
    I have used Plumbing Paramedics when my tank started leaking at the top. They were able to come out on short order. My parents had almost exact same thing happen a few years later and fixed theirs as well in short order, basically next day if I recall correctly. I think it was in the $1900-2100 range both times. We got the AO Smith Proline Commercial Grade ones. I opted for the upgrade to get an extra anode rod installed.
    That's all I do, but what brucebanner said is probably the correct way.
    Dec 2004
    YYC and YVR
    I had Pete the Plumber replace mine a while back for $1008 installed for a 50G tank, obviously it's gone up now though. I saw an ad recently where he used his truck as a bowling ball to crush some tanks. In that ad, he said it was $1500 for a 50g installed - goodman is the brand.
    My buddy needed to do an emergency replacement and he went through Knights Plumbing and they charged him $2500...
    Just don't call Clearview. Never use Clearview.
    Aug 2003
    Medicine Hat, AB
    It's pretty simply to replace one if you can manage to use a pipe wrench. Things like shark bite fittings have made it pretty DIY friendly. I have done 3 myself already. Watch some YouTube and see if its worth $800 in labour for something you should be able to do in an afternoon.
    Aug 2011
    Strathmore
    2005 Dirtymax
    If you can replace a hot water heater you should be skilled enough to not need sharkbite fittings and do a proper solder job.
    How much do these whores weigh? Seems like the toughest part would be moving them up/down stairs.
    Are lifting straps the key?
    Yes, yes and yes.
  1. Recommendations for Hot Water Tank Replacement
    By npham in forum Home and Garden
    Latest Threads: 06-25-2018, 11:20 AM
  2. Looking for Hot Water Tank Replacement Advice
    By dam_guy in forum Home and Garden
    Latest Threads: 04-10-2015, 06:21 PM
  3. LF: Plumber, New Hot Water Tank, Water Softner
    By Env-Consultant in forum Home and Garden
    Latest Threads: 11-06-2014, 11:22 AM
  4. Please service my Hot water tank-no hot water!
    Latest Threads: 12-30-2012, 09:29 PM
  5. Hot Water Tank, no hot water.
