Retaining wall contact? - Beyond.ca - Car Forums
Results 1 to 20 of 28
Thread: Retaining wall contact?
    Jul 2002
    calgary, alberta, canada
    Mall Crawler
    Default Retaining wall contact?
    We have a single 6x6 post that is rotting out on our retaining wall. I have been having a hell of a time finding someone who could replace that single post (tried a contact through Jordan already). I am guessing most don’t want to touch it because it’s a single post rather than a whole wall. Does beyond have a good contact that has experience with this kind of work?
    It may not be possible to replace the single post without that section of the wall failing and being rebuilt. Could try putting in posts on each side maybe?
    No. But the key to the repair is to temporarily brace the living blue Jesus out of it in two places and then remove the old one and drill a new one in.
    Actually... The better key is likely to install two new ones and then remove the old one, or just fuckin leave it there.
    Jul 2002
    Mall Crawler
    Another shot of the wall
    Only 15min from Aspen!
    Nothing interesting anymore
    Use multiple clamps to suck the cracks back together. Bolt both have together. Start saving for a proper brick retaining wall replacement.
    Is it actually rotten, or just split? If it's just split, you could drill into it a bit and then suck it back together with a few deck screws.
    Jul 2002
    Mall Crawler
    Sadly the previous owners didn’t seal it properly and it has rotted out. We are looking to move in the near future so putting in a $20k stone wall is something I’d prefer to avoid if possible.
    That wall should might require a professional engineer to sign off on any modification. That's probably why the legit contractors are avoiding this project.
    The less you change that original design the better.
    Quote Originally Posted by finboy View Post
    Then still do what I said, but when it comes time to sell, slap a facade around it so they can't see the crack.
    /kijijicarflipper
    Well the correct half asses answer is the following.
    Fill crack. Paint. Fixed.
    Any reason you couldn’t run a big bolt through it to prevent the crack from spreading?
    If it’s not rotten that might actually work pretty well.
    Big ass bolt and big ass washers, and filling the crack, and painting over the whole thing, is absolutely NOT the right way to do it. Probably would be my first choice though.... Glad I'm not that kind of engineer.
    Big ass bolt.
    Big ass bolt.
    Big ass bolt.
    Cochrane, AB
    Trucks
    Get some 1/4” steel plate cut into 4 squares to match the post width and pull them together with 1/2” threaded rod and fasteners. It will help until the post rots off at the ground, which it probably did.
    Mar 2009
    Silverado
    Not a wood engineer either.. but also vote for the big ass bolt.
    Jan 2017
    Summer car or work truck
    If it's rotted out, a BigAssBolt will make the problem worse..
    Install a post in either side, call it done
    If
    Jul 2002
    Mall Crawler
    Sadly the bolt would likely just cause failure, maybe something like this below?
    https://www.homedepot.ca/product/sim...ost/1000681911
    Apr 2006
    Cowtown
    10' 4Runner SR5
    Get 2 of these, a 4x4 on either side and three large bolts to sinch the rotting post while also stabilizing it.
    https://www.homedepot.ca/product/pyl...2351?rrec=true
    Ultracrepidarian
    V8s
    This is what I was going to suggest, but heavier gauge. Make it basically as tall as the above-ground portion of the post, one for each side, drilled every 8in for a bolt to go through.
    edit: Should note that a decent home inspector will still catch this and flag the post/wall as requiring replacement... but lots of home inspectors aren't decent, and you might just get lucky.
    Sep 2012
  1. Retaining Wall
    By Travel_Dude in forum Home and Garden
    Latest Threads: 09-16-2011, 01:35 PM
  2. LF: Someone to build a retaining wall
    By Czar in forum Home and Garden
    Latest Threads: 05-02-2011, 06:43 AM
  3. Fence/Retaining wall combo question
    By 84Aquarius in forum Home and Garden
    Latest Threads: 08-12-2010, 12:19 PM
  4. retaining wall and fence at back of house, how to?
    By nonofyobiz in forum Home and Garden
    Latest Threads: 05-25-2010, 09:28 AM
  5. LF: Someone to build retaining wall
    By Euro838 in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 06-20-2008, 09:39 PM
