Anyone out there know where i can find a 48mm throttlebody for a 98 Dakota v6? Any help greatly appreciated.
are you sure it's THAT small?? my neon comes with 49 and 52mm tbs, and it's only a tiny 2L, not a V6 truck
holy jebbus, mines 62mm! sorry to thread jack,
are you looking for aftermarket or OEM?
The V6 TB is a dual set-up (i.e. there's two 46mm TB bores).
To answer your question, the Fastman seems to have the best prices for re-worked factory units ... the other option is to take it to a local machine shop, they'd probably be cheaper yet.
http://www.thefastman.com/Throttlebodies39.asp
you said you wanted 48mm though and I think he only has 46mm.
the other place to poke around would be www.dodgedakotas.com
or http://www.dodgetrucks.org/forums/index.php
hope that helps!
thanx alot for the help, i'll give the fastman a try
