RV Camping; Tips, tricks & repairs - Page 150 - Beyond.ca - Car Forums
Page 150 of 150 FirstFirst ... 140 149 150
Results 2,981 to 2,998 of 2998
  1. #2981
    Aug 2003
    Medicine Hat, AB
    That doesn't seem good unless you were pulling a rail car at 130...
    I thought those things got closer to 12 unloaded and 14 pulling. I think that's what my friend gets in his 2014 although his is a deleted 3500.
    Thats real world fuel economy for diesels that haul trailers that actually need a diesel to pull. Guys getting 14l/100km are the guys pulling a 20ft hybrid's and probably sit down to pee.
    The gearing also matters a lot. My dually had the 4:10 gears in it with the HO engine. I would get 17l/100km empty or pulling 15klbs. Conversely the 3:42 gears will get considerably better mileage on the highway (sub 10l/100km) but get atrocious towing mileage. You'll also find people using the dash for the numbers when it can be off by as much as 15%. Hand calculated will be more. Always.
  2. #2982
    Mar 2010
    Ioniq 5
    We borrowed a relatives camper setup this summer. When I saw it I thought the wallet was going to cry. F-350 and a 40ft fifth wheel. Then after we finished the 1,400km trip and added it all up we spent almost the same amount as my buddy did with his F-150 and tent trailer. Granted he drives like a tool but it really is crazy how much more efficient diesel is for towing.
  3. #2983
    Pufpp party 2km North of that banjo fest that is Atlas staging area. 100 truckloads of standing dead up here.
  4. #2984
    Well that's surprising. Looks like this trailer doesn't have that hose thing to suck antifreeze into the pump and water lines.
    Need to decide if I will leave it with just air blow or go back and figure something else out for antifreeze.
  5. #2985
    a van down by the river
    Bmw and ford
    Locate the water pump and it is pretty easy to t in a line for winterizing. I did it. Took a me about 10 mins and a trip to Home Depot.
  6. #2986
    '14 Taco
    Ya it’s super easy to add a T or just a bypass kit for $40 off amazon
  7. #2987
    Canyonero
    imo just a blow job is all you need
  8. #2988
    Dec 2004
    YYC and YVR
    Here's the kit i picked up and installed today - worked real well.
    https://www.amazon.ca/Camco-36543-X-...s%2C170&sr=8-5
    On that note, after you guys remove the anode rod, do you leave it off for a little bit to let everything evaporate and such? I drained all the water from the hot water tank but there's still a bit in there and having dropped $1600 to replace the tank earlier this year, I def don't wanna go through that again. Old owner was a cunt and I can only assume he did nothing.
    Anyway after it's totally dry, do you guys toss something in like a rag or do you put the rod back? Online some people said toss the rod back in so the threads don't rust, others leave it open, while others stuff a rag into it? With my old trailer I stuff a rag in it to keep mice or bugs from getting it was all. But yeah...rust paranoia.
    Thanks!!!
  9. #2989
    Aug 2012
    Down by the River
    GMC Sierra, LX570
    My first year winterizing a trailer so take the following with a grain of salt. After a stack of reading and YouTube, I just did the compressed air method, running each tap until no moisture present. Then I added anti-freeze to every toilet bowl, and P-trap - total of one 3L jug.
    As for the hot water heater, I drained it, let it drip for 12 hours and then put the rod back in. There shouldn’t be enough water left in the bottom to cause any issues as there will be lots of room for expansion. Trailer is also located in a place warmer than our climate, and with much less chance of > -10 weather.
  10. #2990
    Sep 2005
    If you blow out with air, make sure you drain the water filter if your trailer has one. I made that mistake once.
  11. #2991
    Sep 2012
    I leave the anode rod out the entire winter.
    You must, must, must put anti-freeze into the toilet pump, faucets and the shower head.
    If you use compressed air to blow everything out there's a very good chance it won't get everything out of the toilet pump.
  12. #2992
    Dec 2004
    YYC and YVR
    yep i blew it out with air then ran anti-freeze through the system. I did also flush the toilet to get all the water out till it was pumping out the pink stuff and ran the shower head inside and the outside as well.
    @suntan do you stuff anything into the water tank after you take the anode rod out to prevent rodents and bugs??? I used to stuff a rag into the tank with my old trailer but ever since i experienced the rust issue with this new used trailer, and had to replace the tank, I'm paranoid now re: rust and having to do it again.
  13. #2993
    Sep 2012
    I don't do anything in terms of plugging up the holes. I also leave the drains open on the bottom of the trailer.
  14. #2994
    Bmw and ford
    I just take the shower head off now. I had one permanently stained pink, so now I just take it off. Also remember your outdoor shower … mine is by the poop hose so the only time it gets used is during winterizing and dewinterizing
    I use one 3 or 4 litre and run it though the system and p traps …
  15. #2995
    Aug 2003
    Medicine Hat, AB
    I do both. I blow them out then run antifreeze. Blowing them out isn't really necessary but I do it for peace of mind. Blowing them out only though isn't reliable unless you have a super high CFM compressor and can basically dry the lines with the air. There is always low laying pipes that collect water or it gurgles back on top of the sink valve after you shut it off and still pops out the faucet neck when it freezes.
  16. #2996
    Get ready for winterizing guys. Dehumidifer packages from teh dollar store. I get these at Dollarama:
    Attachment 93929
    Buy your dessicant shit at dollar store, annual reminder.
    - - - Updated - - -
  17. #2997
    LoL! I bought so fuckin many of these this summer for the cabin I felt like I was the bad guy in Se7en
  18. #2998
    Oct 2012
    2010 S4
    Well made our first big trip in the '73 Trillium 1300. Have some ideas on where to make improvements for next year. First up getting a new axle that thing is shot.
    By zipdoa in forum Mechanical
    By A790 in forum Video Games
