Storing cars for long periods of time - Beyond.ca - Car Forums
Results 1 to 18 of 18
Thread: Storing cars for long periods of time
    Dec 2002
    A l337 chair
    Default Storing cars for long periods of time
    I've got my 97 cavalier under a tarp. I plan to keep it under there for a while. When I have a nice summer car, the cavalier will be the winter beater. To keep it running well what should I do?
    I heard you should keep the battery terminal unplugged. I also heard you should start it up and let it run for a bit every once in a while.
    Dec 2002
    UA6
    i heard you shouldn't keep it under a tarp because condensation builds up under it and fucks it up, and you shouldn't just like warm it up once in a while.. dunno if this is true??
    Dec 2002
    the titty bar...
    starts with a screwdriver...
    fill the tank,disconnect the battery, dont start it every once and a while and leave the widow open a crack so condensation doesnt build up.
    I MAKE BALLER CARS MORE BALLER.....
    Aug 2002
    Sep 2002
    Fill the tank, disconnect battery, and inflate tires, that whats they told me to do for my porsche. So I hope that is the right way to store your car. Starting once in a while? I don't know but I can't because its in a storage garage.
    Dec 2002
    the titty bar...
    when you let your car sit for a while the fluids drain out of the hoses and back into their resivoir tanks, if you keep starting the car the fluids stay in the lines and can freeze and split hoses. it wont hurt the car if you start it a few times but its better to leave it, just make sure theres lots of gas in the tank and in the spring time add some fresh gas to the tank because gas looses its octane after a while.
    Oct 2002
    Lurking in some bushes outside your house
    S14/D21
    Put it on jack stands dude if you are keeping it stationary......if you are gonna run your car take it round the block to keep everything lubricated.
    Vancouver
    if you have rear drum brakes, don't put the e-brake on. The shoes can rust up to the drums.
    (maah raahde)
    I've heard this too. I was told if you leave your car stationary for extended periods of time (I'm talking more than just a few months though), your tires may warp. Anyone know if this is true?
    Feb 2003
    Cow Town
    1992 B18a
    Yah this is true, because after a long period of time your tire will take shape to the displaced air in the tire, causing warpness. Its best that you put it on jacks or place winter or beater tires on her.
    CowTown
    Brick Type R, SC AW11, Alcyone
    Where is that thread someone started a long time ago that had tons of info on storing a car and what measures to take?
    omgwtfbbq
    oreo cookie
    a wrx.
    how long?
    Aug 2002
    You can buy those tire saver thingies if you feel like splurging...prevents flat spots.
    Feb 2003
    my dad has an old porsche 75 911, that he puts away for the winter, he puts it on jack stands cause otherwise the tires do warp, its not just old tires that do it either.
    Dec 2002
    the titty bar...
    its not good to use jack stands because the pressure in your shocks can leak and its bad for the suspension. put beater tires on it and if you leave your tires on it the flat spot will come out with a bit of driving. just make sure theyre properly inflated.
    Feb 2003
    Cow Town
    1992 B18a
    I agree, the best thing to do is put beater tires on your car, ones
    you would never use again would be best. Unless you decide to
    remove all your tires leaving only the brake pads, then by all
    means jack her up, but its a little shaky if yah know what i mean.
    Feb 2003
    err, just checked, he has funny blocks he puts the suspension on, weight still on suspension but not on the tires.
  1. everyone's top 10 fav cars of all time
    By infamous in forum General Car/Bike Talk
    Latest Threads: 11-29-2004, 01:14 AM
  2. Storing your car this winter?
    By max_boost in forum General Car/Bike Talk
    Latest Threads: 10-31-2002, 08:14 PM
  3. many cars on shagganapi *long*
    By 2K255HP in forum Street Encounters
    Latest Threads: 10-13-2002, 02:13 PM
  4. Looks Like Its Time To Put Our Cars Away Boys..Snow
    By TomTom in forum General Car/Bike Talk
    Latest Threads: 09-20-2002, 04:34 PM
