smoking and sprinkler systems - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: smoking and sprinkler systems
    Dec 2003
    Default smoking and sprinkler systems
    i have b'n wondering would a ciggerete cause a sprinkler system 2 go off?
    for ex. in a university lecture hall if one wuz 2 smoke owuld the detectors go off?
    May 2004
    Ford, Acura
    We have the sprinkler system at work and they dont go off when the boss smokes. But if the lecture hall is a "Smoke free facility" there could be a decent sized fine for smoking
    I'm generally cute.
    Apr 2004
    LX 5.0
    if you look closely at 99% of sprinkler systems, they are temperature controlled not smoke controlled. so unless you were smoking your cigarette within an inch of the sprinkler you would be ok. Im not sure if that is the best place to smoke though.
    Nov 2003
    Vernon, BC
    2017 Golf TSI
    Depends both on the type and proximity of the detector. Different detectors check for different things, some check the opacity of the air, some the conductivity of the air, while others are heat detectors. I have seen some very sensitive heat detectors go off when a lighter is lit, but that would never cause the sprinklers to go off. They all have either a piece of lead, or another low-temperature melting device on the end, whose sole purpose is to plug the hole the water will come out of. Once they get hot (usually 40-60*C) the blockage melts, and you get wet.
    So, you may set off some specific smoke/heat/fire detectors if you are close enough, but the sprinklers will not go off.
    BTW, don't ever smoke in a university lecture hall.
    Dec 2002
    B6 A4 3.0Q
  1. Replies: 20
    Latest Threads: 10-17-2005, 10:00 PM
  2. Few questions about remote starting systems and the seperate pagers for alarms
    By AllGoNoShow in forum In Car Entertainment / Electronics
    Latest Threads: 04-01-2005, 10:53 PM
  3. Going Rate on Compustar Systems and their installs.
    By Ben in forum In Car Entertainment / Electronics
    Latest Threads: 01-06-2005, 04:39 PM
