Using car for short periods during winter... - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Using car for short periods during winter...
    Aug 2008
    Quebec
    '06 Impreza 2.5i
    Default Using car for short periods during winter...
    Hello!
    I've been told that using my car for a short period (i.e. 4-5 minutes at a time ; I live relatively close to where I work) can be pretty bad for a car during winter (I live in Quebec).
    Is that true?
    Home of the Flames beaotch
    the bandwagon!
    epic fail! is this a serious question. Not to be a asshole, If you warm your car up and drive it a couple mintues, its not going to hurt the engine
    Sep 2006
    I've heard that as long as the car hits normal operating temp before you turn it off you're fine.
    AB
    16' Tacoma Offroad
    It will run rich the entire drive to work and back, which basically destroys gas millage.
    I have the same commute, and I simply deal with it by plugging my car in.
    Car reaches operating temp in a shorter time, and the oil is warm so it lubricates better for those cold starts.
    Sooner you get to operating temp the better. Even on a 5 minute drive.
    Just make sure that every month or so, you take it for a longer drive. You want to be able to boil the moisture out of the engine oil once in a while.
    AB
    16' Tacoma Offroad
    Also, charge the battery when possible, its said that it takes a car 30 minutes of driving to maintain a healthy charge for the battery.
    I charge mine every 3 months.
    Aug 2003
    1989 MA70, 2006 UZN215
    I hope that's not a serious answer! I haven't you heard from everywhere that the engine carbons up from not getting to proper operating temp? Even in -30 degree temperatures and your gauge is showing normal operating range is still well below of where it should be. The longer you let it idle, the more moisture it builds up inside, driving it for a while and getting it to normal operating temperature will prevent this. (Electric fans kicking in, or the opening of the T-stat. Driving it for 10 mins when it's cold will NOT warm up the engine completely.
    the bandwagon!
    i said WARMS UP!!!!! Sorry I didn't give a precise time and temp. I keep my car pugged in and drive it slow for at least 5 mintues and it seems just fine to me. And this is after 10 years of winter driving on the same motor No harm done to the ol' Lexus
    Apr 2005
    if you warm it up fully most the time and take it for a good long drive now and again it will be fine.
    but a short drive without warming it up will be hard on the engine, water will sit in your exhaust and rust it out from the inside out.
    and you will need to change the oil more often as well due to moisture
  1. Short Film Using 5D Mark II
    By Xaroxantu Zero in forum Photographer's Corner
    Latest Threads: 09-24-2008, 11:13 PM
  2. caring for car during winter
    By whitexboi69 in forum Car Care, Detailing and Body Work
    Latest Threads: 11-03-2006, 10:29 PM
  3. Replies: 52
    Latest Threads: 07-21-2004, 02:50 PM
  4. The final word on break in periods?
    By Davan in forum General Car/Bike Talk
    Latest Threads: 11-04-2003, 07:20 PM
  5. Storing cars for long periods of time
    By mrmattyk in forum General Car/Bike Talk
    Latest Threads: 02-09-2003, 09:15 PM
