Hey guys,
I'm doing a brake job and I need the right tool to remove a 17mm bolt holding the brake caliper bracket in place. Can't get enough torque using a regular ratchet.
Do I need an air tool to get it off? Here's a similar pic.
Hey guys,
Use a snipe
snipe
breaker bar
turn the steering wheel so the bolts are easier to access and apply more torque to.
if you have access to a big pry bar, use the bar's leverage against the ratchet and a control arm for more torque
Shouldn't be all that difficult. Put some penetrating oil on it and let it sit for a bit. If you don't have a breaker bar, you can use a ratchet extension with a socket at the end which fits the end of your ratchet handle. (Makeshift breaker bar for more leverage)
double up combination wrenches
Originally posted by ZorroAMG
Kinda like this morning when I wanted to tell my GF to pass the sugar and it came out "You fucking bitch, you've ruined my life."
A trick that I used to use to get stuck bolts out (before I bought an impact wrench) is to position the socket horizontally then put a jack under the end of the socket and jack it up. Used this method to do my brakes and to get a wheel hub off.
Manual Impact wrench, Put on your ratchet and nudge it with a rubber mallot.
ThisOriginally posted by EM1FTW
Instead of a ratchet, I smash with a steel hammer on the open end of a combo wrench (use safety glasses).Originally posted by Ichigo
Ratchets can break a cam.
Also, try some PB penetrant. This stuff is amazing, I loosened the lower control arms on my 8 year old Civic with no problems after letting it soak over night.
^ Is that stuff better than Liquid Wrench?
Ya, I switched.Originally posted by G-ZUS
WD40 < LW < PB
A 24" breaker bar did the trick. Thanks guys!
