NoPulp Build Thread - Boosted V6 Mustang - Beyond.ca - Car Forums
Page 1 of 9 1 2 ... LastLast
Results 1 to 20 of 165
Thread: NoPulp Build Thread - Boosted V6 Mustang
    Mar 2015
    Lethbridge AB
    1994 Mustang, 2007 F150, 1991 Volvo 240 Wagon
    Talking NoPulp Build Thread - Boosted V6 Mustang
    Hello,
    Some members requested a build thread on my car, so here we go.
    Please feel free to comment and ask questions. The car is far from complete (will never be complete) so I will update it as it goes.
    The car was purchased in 2007 as a father-son project. It had just been used as a donor car for a gt that had hit a deer and its next destination would have likely been the crusher.
    All the work was done by my father and I in a standard 2 car garage including the paint. The project started off with an engine swap since the barely running 3.8 v6 wasn't really an option. Of course a v8 engine swap is the first thing that comes to anyones mind, but we had also heard of some interesting v6 builds. We started doing some research and ended up finding a wrecked F-150 with a 4.2 v6 that could be swapped into the mustang.
    The 4.2 is a similar engine to the original 3.8 but with the main differences of larger displacement and split port. Boost was the second part of the equation. There had been some people that used an adapter plate to fit a M112 supercharger from the 03/04 cobras onto a splitport v6. Sounded like fun, build a v6 that could beat up the v8s of its era.
    So in conclusion, the idea behind the build was to do something different. (Something that's not often seen in the mustang community...)
    Mod List
    Engine
    4.2 v6 (1998 F-150)
    M112 Supercharger w/2.93 pulley
    Water Methanol Injected
    SSM adapter Plate
    Mild ported split port heads and intake
    Comp Cams 259HR115 cam
    Comp Cams 26918 valve springs
    Scorpion 1.73 roller rockers
    Lightning 90mm MAF
    C&L boost pipe
    Walbro 255lph pump
    Cobra Blue 39lb injectors
    94 3.8 v6 stock headers
    94 3.8 v6 25% underdrive pulleys
    Double roller timing chain
    Stock polished valve covers
    MSD Coil
    Drivetrain
    T5 transmission (95GT)
    King Cobra clutch
    Stock clutch cable
    Triple hook quadrant/ locking firewall adjuster
    Mac shifter
    8.8 fox diff assembly 3.73 gears
    Interior
    00’ Mustang interior
    Boost gauge
    Billet pedals, turn signal, defrost, temp controls, headlight control, Ebrake
    Fog light switch
    Hidden antenna
    Alpine stereo
    Collection of Pool Ball shifter knobs (favorite: orange #5)
    LED Swap - gauges, hvac, dome.
    Innovate Wideband
    Dual gauge column pod
    Exterior
    Cobra bumper
    Cobra R hood
    Depo black diamond headlights
    Depo chrome diamond corners
    Cobra fog lights
    Stock horizontal taillights
    Wingless
    Antenna removed
    Passenger door keyhole removed
    Bullitt Wheels 9" front 10" rear
    255/35ZR18 Hankook Venture Plus front
    275/35ZR18 Kumho rear
    Monster extended open ended forged steel titanium finish Lugs
    Paint: 94 Ford “Orange” - used on pickup trucks
    LED Swap - License plate
    Vanity plate - NO PULP
    Suspension
    HAL Kmember
    MM CC plates
    Eibach Pro- kit springs
    Tokico D Spec Shocks Struts
    Front FRPP Control Arms
    AM UCA and LCA
    Exhaust
    Mac Cat Back w/polished tips
    Pacesetter H-pipe
    Gutted Cats
    Now pictures of the build. I really wish I had taken better and more pictures throughout the process.
    Original condition
    Engine Build
    Swap
    Mar 2015
    Lethbridge AB
    Exterior
    Suspension & Interior
    Don't really have an pictures of the suspension and interior upgrades. The suspension was all replaced with a bunch of goodies highlighted in the mod list. The interior was completly gutted and the resembled from the few usable stock pieces and an 2000 mustang interior. There was also the 8.8 rear end swap.
    From there the car was painted and reassembled. I drove it like that for a year or two, then the supercharger went on.
    It uses an adapter plate from SSM
    There was obvious good clearance issues, so work had to be done.
    With the blower came heat. Since I cant really put an intercooler underneath I am using Meth to help cool things.
    I also did an LED swap...
    That is a super quick walk through of the build... Just a quick summary really. Next I'll post some more current pictures, videos and dyno results.
    Mar 2015
    Lethbridge AB
    Mar 2015
    Lethbridge AB
    Some of the pictures taken by Kevin Chow (unkicrackie99) . Some of the pictures were taken at the closed mental hospital in Raymond Alberta.
    If you are on mobile, they'll likely show up weird... Not sure why.
    1994 Mustang - SBF swap in progress
    Nov 2004
    edmonton
    Ford
    Man that is a sweet job you did there. especially with the supercharger swap
    I remember how shitty the N/A 4.2L was. it was the engine in my first truck a 97 F150. couldn't even turn over one tire fire.
    Street Tune
    Mar 2015
    Lethbridge AB
    I've started to try to get into photography, so here's my latest work.
    1994 Mustang by richaaarrrddd, on Flickr
    4.2 V6 w/ M112 Supercharger by richaaarrrddd, on Flickr
    IMG_0630.jpg by richaaarrrddd, on Flickr
    IMG_0627.jpg by richaaarrrddd, on Flickr
    IMG_0633.jpg by richaaarrrddd, on Flickr
    IMG_0634.jpg by richaaarrrddd, on Flickr
    IMG_0662.jpg by richaaarrrddd, on Flickr
    IMG_0666.jpg by richaaarrrddd, on Flickr
    IMG_0665.jpg by richaaarrrddd, on Flickr
    IMG_0667.jpg by richaaarrrddd, on Flickr
    IMG_0669.jpg by richaaarrrddd, on Flickr
    IMG_0670.jpg by richaaarrrddd, on Flickr
    IMG_0673.jpg by richaaarrrddd, on Flickr
    IMG_0659.jpg by richaaarrrddd, on Flickr
    May 2009
    G37X
    Generally not a huge fan of that gen mustang, but this one works really well. What kind of power does the blown 4.2 put out?
    Mar 2015
    Lethbridge AB
    I seem to get that a lot. The generation isn't terribly desirable, but I think they can look great with some tweeking.
    Numbers with plugged cats and bad 02 sensors...
    288.1 RWHP
    307.4 ftlb
    At Flywheel
    330.4 HP
    352.5 ftlb
    https://www.youtube.com/watch?v=4y109k-c-x8
    With the bugs worked out, it should now be at the 300whp point which was my overall goal for the build.
    This is a fairly safe setup, there have been people that have pushed the block to 600. I believe at 600 the studs pull apart.
    Jun 1987
    SK
    Fit Dugan Signature (2016)
    The orange sure works for that car.
    Originally posted by SJW
    Originally posted by snowcat
    Feb 2008
    teslo murdel free
    Love it! like others have said not really a fan of that generation. But this build is awesome! You need some ford racing seats and a different steering wheel!
    Grimace
    Very cool build. Lots of impressive works from the original pics until now.
    Mar 2007
    Edmonton area
    Has wheels
    Like others, not my favorite gen but I really like them with the cobra bumper and hood. Creates a whole new look I think. I think not really being able to do something with the exhaust tips is what gets me about this gen, something so trivial.
    That said, very cool car. Looks awesome and props for a different build!
    Mar 2015
    Lethbridge AB
    Thank guys!
    Thank you. The interior is definitely making its way up on the to-do list. Seats being the major thing. As for the steering wheel... unless I could find a 10th anniversary wheel for a decent price (impossible) I'll be sticking with the stock wheel. Aftermarket wheels look horrible because of the chunky steering column cover. I will hopefully be doing something with the stock wheel to make it a million times better.
    Thanks! What do you mean not being able to do something with the exhaust tips? You can do anything you want with these cars. Get huge tips, dumps, termi exhaust, even side exhaust with the svo side skirts. Exhaust is easy to customize, but since its a mustang the aftermarket is endless.
    With the v6 I don't want to change my exhaust too much from current, I think I've made it sound very good. Its really easy to make a v6 sound horrible lol.
    Mar 2007
    Edmonton area
    Has wheels
    I guess all I was getting at is that it's often you see people running their tips similar to what you have done. For me, it's too much tip (from a side profile). Just me being picky with that gen is all.
    Mar 2015
    Lethbridge AB
    Ah, I understand now. Mine are fairly long and a good portion of the SN95 community run them the same. You can get shorter tips. I do think the shorter tips look goofy because you can see so much of the side profile.
    May 2007
    has a stick axle
    How much power are you currently making with this unique setup?
    288.1 RWHP
    307.4 ftlb
    At Flywheel
    330.4 HP
    352.5 ftlb
    i'd say somewhere around the above
    Foothills County
    is faster than yours
    Car looks great...excellent job! And kudos on going with a unique powerplant!
    very nice build.
    Mar 2007
    550i, X5
    Absolutely beautiful if you ask me. Just so nicely done! I want to see and hear this car so bad...excellent work. I wish I had those skills.
    Originally posted by rage2
    Of course, a perfectly good explanation is boring, so the answer is, it's fucking voodoo.
  1. Replies: 87
  2. NoPulp's Track Build
    By NoPulp in forum The Garage
    Latest Threads: 06-28-2017, 07:06 PM
  3. Replies: 6
    Latest Threads: 08-05-2011, 09:56 PM
  4. Boosted 3
    By ACS-e36 in forum Cars, Bikes, Machines
    Latest Threads: 10-06-2003, 07:05 PM
  5. buh_buh's boosted Lude
    By cocoabrova in forum Cars, Bikes, Machines
    Latest Threads: 03-03-2003, 05:58 PM
