Yeah I tried two different PSU power cords, with the UPS but in a non-battery backup slot, without the UPS straight into the wall, and without the UPS straight into the wall using an extension cord to an outlet I am pretty sure is on a different circuit. Also, as you brought up, the issue happened at the service desk at Memory Express when I dropped the computer off for diagnostics, which theoretically would rule out my house power being the issue. Unfortunately the issue did not happen on the tech's bench a day or two later when he ran all the tests.Originally posted by Seth1968
You tried it without the UPS right? Although it could still be a line issue.
The other factor is it happened once at Memex (that we know of). I say that because like any repair tech, we shudder at intermittent issues.
Only thing I haven't done is move it to a different house, and see if it works. Problem there is if it works, I won't know for many days if it's just behaving temporarily or not. Also, it worked for over a month at my house without issue prior to the shutdowns.
