Making small outdoor handrail - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: Making small outdoor handrail
    May 2009
    G37X
    Default Making small outdoor handrail
    Hey all, looking for a little bit of advice. I'm looking at putting in a small handrailing for my grandmother to help her get up her front 2 steps of her house. These are the steps: http://imgur.com/a/R0p0c . She currently is grabbing onto the corner of the bricks, which is a bit of a reach as there is a tree in front of it. I'm looking to put in a simple railing/handle on the steps to make it a little easier for her. My current plan is to grab 2 pieces of 4x4 and anchor it to the existing porch with deck screws, then put a small 2x4 or something across them and screwed into the 4x4's. I was planning to attach the 4x4's with L brackets. Wondering if this is an OK plan, or an absolutely terrible plan? Hoping to get a second look at it from people who know this stuff better than I do.
    Thanks
    If you're handy with a hacksaw, we just put two sections of wrought iron and wood handrail outside at my uncle's place - free for the taking and in excellent condition. One section is for a set of stairs, the other for a flat area.
    Will fuck off, again.
    6.7 CUMMINS, E50 AMG
    I'll offer to re weld the parts for free if you cut them to fit
    Okotoks North
    Your original plan sounds good too, but instead of L brackets, use something like this:
    https://www.homedepot.ca/en/home/p.p...000674747.html
    It'll be more sturdy.
    May 2009
    G37X
    Thanks for the offer. Is it something that'd make sense for just the 2 steps? Definitely don't need anything too crazy just something to give her something to make sure she stays balanced going up and down. I'm sure it'd look nicer than what I'd be building though.
    Super kind, thanks. I've got access to a welder at work so won't need it though.
    Definitely looks better and should be more secure than L brackets, thanks.
    That's your call to make, not mine. What you're making needs to be sturdy at best, how good it looks is all up to you.
    Feb 2005
    calgary.ab.ca
    E90M3 510 Wagon
    I'd pop off a couple boards, attach 4x4s to the joust and the step riser with lag bolts, cut deck boards to refit, then 2x4 horizontally on top of 4x4s, and in between about halfway down and some 2x2s or similar vertically between the 2x4s
  1. FS: Clear Cedar Handrail Beaded Wood
    By dam_guy in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-21-2012, 06:40 PM
  2. Building Code - Handrail off a deck
    By Masked Bandit in forum Home and Garden
    Latest Threads: 09-13-2011, 05:22 PM
  3. Replies: 7
    Latest Threads: 11-11-2010, 12:31 AM
  4. FS.4 Small/X-Small Lacoste Polo Tops
    By Neil4Speed in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-21-2005, 03:39 PM
