PC Build Thread - Page 54 - Beyond.ca - Car Forums
Page 54 of 66 FirstFirst ... 44 53 54 55 64 ... LastLast
Results 1,061 to 1,080 of 1319
Thread: PC Build Thread
  1. #1061
    If anyone needs a 3080 or 3090 they have some in stock at memex in the NE
  2. #1062
    Moo Town
    (0^oo^0)~
    Have the LHR variants made their way into stores yet?
  3. #1063
    Definitely
  4. #1064
    Moo Town
    (0^oo^0)~
    I'm pretty sure I would have gotten my TUF 3060ti if I didn't rely on Dalhousie Memex lol.
    C'mon waitlist! Let me at em before the end of the year!
  5. #1065
    Got everything up and running! The motherboard doesn't seem to want to play nice with the ram though. G.Skills has it on their QVL, Asus doesn't and refuses to care. Might have to try using only 32 instead of 64 gb and see if that works. The ram is rated to 3600 but will only show 2133. Tried manually "overclocking" it to 3600 and won't boot stably, reverting to safe mode/defaults.
    Not sure what to do! Has the latest bios installed.
  6. #1066
    May 2007
    has a stick axle
  7. #1067
    I was thinking that too but it seems like XMP is enabled. I'll double tomorrow thanks
    Even still, with defaults and the shortcomings with RAM, benchmarks are x6-7 better than my older PC lol
  8. #1068
    Mobo QVL is the "bible" so to speak, not GSKILL's QVL. It also matters 2 sticks vs 4 sticks for QVL.
    A few things to try:
    1) Make sure BIOS is the latest
    2) Try "training" the RAM (set XMP but then manually downclock to 3200 or something below 3600 - if that works then try raising it up to 3600)
    3) Try increasing the RAM voltage manually slightly above 1.35V - you're probably OK up to 1.40V but no more.
    4) Try loosening the timings manually (the mhz is more important for Ryzen)
    5) Sometimes you can't use XMP with 4 sticks of RAM if it's too much stress on the memory controller - take out 2 sticks and see if XMP works (with 2 sticks, install them starting farthest from CPU, opposite of what seems intuitive). This will also tell you if 4 sticks is the issue.
    5) Swap to a mobo that has that specific 4-stick kit on the QVL or a ram kit that is on the current mobo QVL
    One more thing to add is if your ram sticks are dual rank, they are harder to overclock especially in 4X configuration.
  9. #1069
    So my noob is showing, but I didn't realize that XMP and DOCP are the same things. DOCP was then enabled and booted with no problem. Basically, it cranked up the voltage and changed the timing parameters automatically once I selected the profile.
    G.Skills was really quick about replying to my email and suggested a few other things. The standard is 1.35V but some others have had issues with 4 DIMM ram and changing it to 1.36V helped.
    Now I just need to benchmark the ram and ensure it's all good and can start playing around with O/C the CPU.
  10. #1070
    Yup - that is exactly how the profiles work on both Intel and Ryzen. Basically an automatic safe overclock. My mobo for example still calls it XMP even though it's obviously Ryzen. To confirm it's truly working, you can use CPUz or Ryzen Master and make sure the memory clock is 1800 (it will show half of 3600 because of the DDR).
    Glad you got it working, nice when it's a simple fix, especially with computer related stuff.
    For OC just enable PBO2 and that's really all you need to do. The CPU will automatically overclock itself safely and within the limits of both your cooling setup and the power handling of the CPU. If you want to go one step further you can apply some negative offset to the curve optimizer which works hand in hand with PBO2.
  11. #1071
    Yep RAM is working and I stress tested the system using AIDA64. Temps are really good, I'm quite impressed with the cooling especially given the Lian Li O11 case design. I would like to configure the case fan speeds in Windows in real-time vs. the BIOS because while mining I want the bottom fans higher.
    Need to look into O/C the CPU later. It's hilarious though that it processed the Blender benchmarks about 7-8x faster than my O/C 2600K LOL.
  12. #1072
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Looking at a new monitor. The current dual screen setup that I've got(Dell U2417H & SE2419H) is great for WFH but terrible for gaming, so I'm looking to get an ultrawide and move the Ultrasharp on top on a monitor arm. Anyone have any suggestions? Don't really have any real criteria other than it needs to be sub $1k and needs to be 32" or larger. I only game casually, most played games are BF3 & 4. Doesn't have to be anything e-sports grade, I'm not that sweaty.
    Was looking at this but have heard some reviews that there's ghosting and flickering problems?
    Rig that I'm running:
    i7 4790k @ 4.7Ghz
    32GB DDR3
    TUF RTX3070
    (Yes I know I'm due for a rig update, I was tempted to update last year but figured I'd wait until DDR5/AM5+Ryzen 6000 is released)
    Edit:
    Scratch all that, just hopped on RFD and was bestowed a Lenovo G34w-10.
  13. #1073
    May 2007
    has a stick axle
  14. #1074
    Nice I like that! For now I have downloaded FanControlV91 which has been handy for manual static percents while mining but for everything else I should use that. The BIOS has fan curves but it really is a PITA as it's not that smooth to click on things.
  15. #1075
    Jan 2003
    Question on buying / selling used GPU... how does warranty from manufacturer work? or is it just to original purchaser? I have a Gigabyte 3070 Aorus master (not LHR) that I have used for a few months. Thinking of upgrading my card if the opportunity comes. If and when I sell my 3070, how do I price it and should I include my receipt?
  16. #1076
    Quote Originally Posted by ZeroGravity View Post
    Some manufacturers follow only the serial number, others require original proof or purchase, but best to double check directly with the manufacturer on the card you are considering as policies do change and user experiences do vary regardless of official policy.
    EVGA will always be the easiest to deal with and the warranty follows the serial number. MSI will warranty products without a receipt but the warranty start date changes to the manufactured date in that case.
    Asus warranties are not officially transferrable.
    Gigabyte does the same as MSI last time I checked.
    All manufacturers seem to be very picky about any physical damage as well so if you have to ship anything, pack it extremely well because any damage is going to happen in a sorting facility.
  17. #1077
    Medicine Hat, AB
    Id be interested if you do decide to sell. As for warranty/receipt, thats probably dependant on where you bought it from.
  18. #1078
    Jan 2003
    Thanks for the info.
    Noted. I would feel more comfortable to sell to someone here than a random person on kijiji. I bought the 3070 Aorus from MemEx.
  19. #1079
    Nov 2004
    edmonton
    Ford
    Finally got mine put together, First build. Now I'm afraid to turn it on see if it boots up.
    Street Tune
  20. #1080
    Thoughts?
  1. Pre build or build out a pc? Need to upgrade my home desktop
    By cycosis in forum Computer Help Desk
    Latest Threads: 02-28-2020, 01:16 PM
  2. Replies: 87
  3. 92 ''Just a Civic'' Build/Story Thread
    By Sparx in forum The Garage
    Latest Threads: 04-28-2010, 05:21 PM
  4. My second silvia build thread.
    By CivicTunr in forum Nissan 240sx / Silvia Owners
    Latest Threads: 08-07-2008, 08:53 PM
  5. Silvia build thread
    Latest Threads: 04-11-2008, 08:08 PM
Tags for this Thread
