93 Civic Si restoration - Beyond.ca - Car Forums
Page 1 of 3 1 2 ... LastLast
Results 1 to 20 of 50
Thread: 93 Civic Si restoration
    06 S2000
    Default 93 Civic Si restoration
    Circa 2015, some friends of mine picked up a 93 Civic hatchback to do some racing in.
    They were looking for something cheap to race, and something they could walk away from if it went boom. They succeeded in racing, and blowing up ~3 engines. One of them was a bodyshop technician.
    Within the 3ish years of racing and blowing up D-series motors, they also decided to do some rust repair, and repaint the car. This unfortunately involved bondo, but it was done on the cheap, and the labour was free.
    Around Feb 2018, they blew the motor again, and decided to reuse the stock bottom end (~300k on it), and pair it with a known good head from the 2nd engine. They put them together, dropped it into the car, primed the oil, and never started it due to leaking fuel injectors. The car proceeded to sit for ~4 years. This was the last picture of it at the time:
    During this time, they sold the wheels, the seats, the ebay header, and a few misc parts.
    In ~ April 2022, they reached out to me, since I had been all over that thread from the beginning, asking if I wanted to buy the car as a non-runner. I expressed interest depending on price, but the matter was soon dropped before a price was provided.
    Fast forward to Oct 2022, and they come to me with a Kijiji ad, a discounted price, and a hint to keep it within the community. After speaking to my wife, I decided to go for it. I was informed it was a non-runner, but likely just because the timing was off.
    I book the uhaul, get told the closest full car trailer to Edmonton was in Cold lake, so I booked one of the smaller FWD trailers, and head up to Edmonton.
    It comes with the 14" Enkei wheels with some winters, the stock seats, the "good" engine, and 3 boxes of spare parts, including a spare intake manifold, the deleted P/S, a bunch of small takeoffs from the various engines, oil filters, belts, etc etc.
    After getting it back home, and pushing it into the garage, I get to work.
    Turns out, the timing belt was off, causing no compression. It cranks fine, but just spins like mad. The cam gear is supposed to be at TDC (or have the "up" marking, point straight up), while the crank pulley is supposed to line up with some markings on the timing cover.
    With the cam pulley in the proper position, the crank pulley is 180* off. With the crank pulley in the proper position, the cam pulley is 90* clockwise. So I do what any sane, lazy piece of shit would do. I pop the belt off the cam gear, reorient it by hand, and push it back on.
    Suddenly, compression! But no starting.
    I spent the next few days trying to get it to start. I tested spark plugs, which seemed okay. I drained the 4.5 year old fuel, and replaced the fuel filter. I checked the throttle body. Nothing seemed to work. I finally said screw it, and ordered a new dizzy, since I didn't have a spare in the box-o-parts (only a new rotor cap).
    Rockauto got me a dizzy and some new spark plugs in 2 days. It took all of 10 minutes to swap it, and when I tried to start it, it caught so fast, I was caught off guard.
    I pulled the code, which was 14 (IACV). After speaking to the previous owner, he mentioned that the IAT and IACV plugs are identical, and to try swapping them. Success!
    Once it was running, I got it registered and plated the next day.
    Once it had a plate on it, I took it for a small shakedown cruise, with a few notes:
    The alternator belt needs to be replaced. I tried all the spares in the box, they all squeal.
    The right turn signal was not working at all. Left was fine, 4-ways were fine.
    Heater would not blow hot, but car was warming up.
    The right rear creaks hard. As far as I can tell, it might still be the OEM suspension? Previous owners never touched it once.
    The driver side window won't roll all the way down. It binds up about halfway.
    Cruise control doesn't work. No idea why.
    So obviously, I needed to address the heat. Using an old Ericthecarguy video as a guide, I just backflushed the heater core using some air, a bit of CLR, flushing it out and refilling the rad. A little messy, but not too much work, and now I have heat. While I was letting the car idle up to temp to burp the system, I left the right turn signal on, and once the car warmed up, it just... started working. Hasn't stopped working. Very weird.
    I decided to take it on another shakedown, and drove it to the gym. It was a champ, but I noticed when I got home that I could smell some burning plastic or rubber. When I investigated, I thought it was the alternator belt, since I could hear weird rubbing coming from that direction, but imagine my surprise when I found out it was the timing belt rubbing on the timing cover.
    Turns out, the timing belt guide was missing off the crank pulley. Not sure how that was missed. Checked my box of parts, and couldn't find one. Reached out to Balance auto about sourcing one and doing the timing belt on the car, but they couldn't get a timeline on the parts. I reached out to Village honda, and the guide was backordered to mid Dec.
    Previous owner suggested maybe it was installed, but backwards, so I spent 30 minutes tearing it all apart to take a look (I'm confident I could do the timing belt on this thing <1hr now), just to find out it is completely missing. But now I have the whole thing pulled apart and all the work done, but the part is a month and a half out. What do I do? I rifle through the box one last time. And sitting there, at the bottom, pushed up against the side, is a single one. So I slap it on, slap it back together, and we're good.
    Next up, I made another order from Rockauto, including:
    Timing belt w/ tensioner
    Hatch struts
    Spark plug wires
    Rear wiper
    Alternator belt.
    I also have some BNIB speakers that came with the car that I plan to install, as well as address the drivers window. I also have 2 different keys, one for the ignition, one for the doors, nothing for the trunk, and no spares, so I plan on re-keying the doors/trunk to match the ignition, and get a spare cut.
    I'm missing a few interior trim pieces, including most of the trunk (tailgate interior piece, passenger rear speaker cover, spare tire cover), but I think I just want to enjoy the POS it is over the winter before going further.
    I'd love to get a small drop on it, some decent summer wheels, a new exhaust, and maybe long-term do a K-swap. Just a cute little hard parker.
    My car sounds like shit.
    Dec 2008
    Unit 91 come in 91
    Love EG civics. I had one as a winter beater many years ago and loved driving it.
    C-Spot
    11sec S14, Lux Family Bus, VQ35HR
    This is great. Car stuff on beyond!
    Good story too! I love it when parts just happen to appear.
    She wishes it was deep.
    So deep put her ass to sleep.
    Sep 2008
    Turbo stuff
    I sold my D series junk to a buddy, but he might still have some parts if you wanna hop this up a bit (or a lot)
    06 S2000
    Quote Originally Posted by Sentry View Post
    I'm interested. I have a buddy who mentioned he has a ton of d-series turbo parts lying around as well. The engine is not.. great. I'm pretty sure when the timing was off it smashed the valves, but it runs. Did a compression test before it was running and pulled 140/150/140/140.
    Jul 2007
    Blue boy
    That's awesome, love eg hatches. had a cx with no power steering and it was fun to drive. btw your link doesn't work, needs a log in
    Feb 2009
    Family Hauler
    Love these little cars. Always dreamed back in the day of buying one and throwing a K22 in it.
    06 S2000
    Quote Originally Posted by G-ZUS View Post
    Oh, that's right, this one has a p/s delete on it. I hate it, but I'm not reinstalling it until I pull the motor for some reason.
    Yeah, the link is to the original build thread, no big deal if the link doesn't work.
    Feb 2003
    DT 780
    LEXUS LX470
    absolutely love this. If I had 1 more garage bay space at my residence I would have an EG sitting in there right now.
    Tap, Rack, BANG!
    06 S2000
    It's.. cramped. The truck sits outside.
    V8s
    One of those things is not like the other. Get that shitbox outta there.
    957,958,NC1,NC3,E90,ITR
    Why don't you like S2000's?
    Sep 2008
    NE
    Ram 1500, '68 Camaro, S14
    haha pretty dedicated honda guy for sure.
    Look forward to more on this thread, love the car content
    Mar 2007
    Edmonton area
    Has wheels
    Nice. Vote for turbo stuff
    C-Spot
    K-swap the mini
    Nov 2007
    Is that a fairly standard size garage? Mine's looks about the same, maybe a tiny bit wider and I was thinking of getting a lift so that my winter car can sleep inside.
    How tall is your ceiling?
    06 S2000
    Quote Originally Posted by Ukyo8 View Post
    I think it's standard.. ish? Like 22x24 or 22x26? Deeper than wider (heyo!). Ceiling is 11 or 13ft? I can't put the s2k on the lift on the top set of locks, just the second highest.
    Dizzy decided to eject the spark plug wire for Cyl 3, so I limped it home and swapped it out for a spare set of NGK wires that came with the car. The ones in there didn't appear to be grabbing on the dizzy that well anymore.
    Took the door apart to try and replace the speakers, but the 6.5" ones that came with the car aren't drop in, so i'll look for an adapter and have a buddy 3d print one, hopefully.
    Also found out the drivers window derails if it's rolled all the way down, so that was fun to get back into the frame. I'll need to clean out the regulator before ordering one, to see if that resolves it.
    The bar to lock the drivers door from the inside had also popped off, so I spent some time losing skin trying to fix that. I need to either bend the bar a little better, or replace it.
    Also keeping an eye out for some new to me suspension. Used parts have been a struggle to find for a 29 year old honda, but ideally I want the Koni 1145-1021 kit (Koni yellow street w/ Eibach springs), but it appears to mostly be discontinued. Debating some cheap Yonaka coilovers, and maybe the Yonaka exhaust, since the exhaust shop one on here currently is insanely buzzy and raspy (although quiet).
    Jul 2008
    Transnistria
    Exploded.
    You shut your whore mouth
    V8s
    Quote Originally Posted by flipstah View Post
    That took longer than I expected.
    Most british cars are shitboxes, change my mind. They just offset the shitbox factor with a bit of... charm?
    06 S2000
    It is definitely a charming shitbox.
  1. Replies: 6
    Latest Threads: 04-19-2013, 09:16 PM
  2. huge Restoration
    By camero in forum Photoshop Gallery
    Latest Threads: 12-08-2004, 06:49 AM
  3. Porsche restoration
    By dsmer in forum Photoshop Gallery
    Latest Threads: 11-27-2004, 08:10 PM
  4. Restoration
    By Drift Master in forum General Car/Bike Talk
    Latest Threads: 04-25-2004, 12:50 PM
  5. Rust Restoration
    By Dave P in forum Mechanical
    Latest Threads: 11-21-2003, 07:29 PM
