Looking to have some dents removed from my gas tank. Its a 70s Honda tank so it's a heavy gauge steel. Any recommendations on where I should take it?
Don't know a place but you could DIY. But you gotta be sure it's free of any gas.
Make some fitting that allows you to put an air compressor on it. Pressure it up (not too much). I'd try 40psi. Then use a torch to slowly heat the dent up. It should then press out.
I've read this is the way it's done. same goes with exhaust cannister dents.
I've used DNT on memorial a handful of times, always left very satisfied.
