Looking for a set of wireless trigger to use with my X-T2 and SB600 flash. I've been out of the strobe game for quite a while, but back then I would use Yongnuo system with my speedlites. Any recommendations for what I can use with my X-T2?
Thanks!
Thanks!
I have this kit plus a third receiver and it is both cheap and excellent:
https://www.bhphotovideo.com/c/produ...ve_lr_kit.html
Those triggers work on most cameras, they likely work on Fuji as well (maybe just confirm with B&H). A lot of Nikon triggers and flash accessories also work on Fuji.
I use mine to trigger two SB-600's and a cheap Amazon flash, everything works perfectly. If you need another flash, this is the amazon Flash I have and it's honestly as good or better than the SB-600 haha:
https://www.amazon.ca/Neewer-750II-S...70_&dpSrc=srch
Flash triggers are grossly overpriced locally so you will probably be ordering something from the USA regardless.
I've been using strobepro's stuff. www.strobepro.com . They are rebranded godox's so it's pretty universal now. Price has crept up there though. Fuji triggers and flashes. Got some new smaller ones.
If you're just looking to trigger the flash, any system will do. If you want to be able to control flash output, sell the SB-600 and pick up some Godox/Strobepro stuff. AD200 is a hell of a flash for $400 and the X60/X35 useful if you don't need as much power. If you don't use TTL, save some cash and get the manual versions with an XT Pro controller.
