Trade you for the Honda fit?
We can do a month swap to see how we each like it. I might miss the Savage speed.
If it's rebuilt, then of course it has passed inspection, otherwise it would be salvage. There is nothing stringent about a rebuild inspection, you take it to Canadian tire, they check all the basic shit, and then give it a pass/fail. I sold a car of mine that got a front fender hit, the buyer drove it straight to CT without doing any work and got it passed.
That being said, nothing wrong with rebuilt status other than it having no resale value if you ever want to dump it. But if you're buying anyway make sure to go over it thoroughly. Big thing is to check alignment. Things can visually pass an inspection, only to find out down the road that your tires are wearing out because you have a slightly bent control arm or something that was never replaced.
I would buy it for $800.00. Mine was in 2 minor claims but it was fixed properly and has active status. As in minor parking lot bumps, not demolition derby crashes like that $8000.00 heap. Worn out clutch? Ghetto rims? NE special, pass !
Side note on carfax, my former 6-6 had a minor bump ($2200 dented bumper and trunk lid) which did not show up on the carproof when I looked at the dealers ad. What's the deal with that?? I reported the collision to CPS and had it fixed properly but still. Does carfax not receive minor claims?
https://www.calgarymotorsltd.ca/cars...d-Coupe-82329/
LOL at 8 months being a long time to keep a car, I thought I was bad for averaging 1.5 - 2 years :rofl:
TL SH AWD with studded winters is damn near unstoppable even in side streets packed with snow and ice. Only limit is ground clearance. I feel like a Subaru guy with class :angel:
Fun update to this. I got the letter for the oil consumption recall today. Sounds like the warranty is being pushed to 200,000KMs.
Seems like the issue is more relevant to the auto cars. Wonder if those have that stupid cylinder deactivation to achieve the better fuel economy.
60% of TL 3.7 v6 owners with autos on the forum reported excess oil consumption vs 38.5% with the 6mt.
A 3.7L engine with Automatic Transmission (AT)?
50
60.24%
A 3.7L engine with Manual Transmission (MT)?
32
38.55%
A 3.5L engine with Automatic Transmission (AT)?
1
1.20%
Is there any liability or recourse as a buyer with a used car dealership selling a vehicle with a severely cracked timing belt that had obviously never been changed? The vehicle came with an inspection from a shop however I don't know if that is something that is checked. Had it broken, I surely could've been in an accident or at the very least had significant valve damage to my engine. I have the old belt for proof if this is something I could go to AMVIC for or ?
Unless you've got an inspection that says they looked at the timing belt you're going to be SOL. The AMVIC inspections are just for safety related item and no dealership is going to pull the timing cover for that.
- - - Updated - - -
I wonder if they sent me one for my 2014.... I'm only at 75,000KM but I haven't noticed any burning yet.
So I adjusted the valves as they were quite loose and not done by prior owner at recommended 170-180 k interval. Turns out the timing belt and tensioner and spark plugs were all original as well - yikes. Belt was seriously cracked. Curiously, I'm now averaging 9.5 - 10 L/100 kms vs 11-13 L/100kms driving on deerfoot in the same spirited/decent manner. Hopefully the decent economy continues! Could adjusting loose valves and replacing original iridium spark plugs with 200 km (still looked reasonable albeit old) really bump my fuel economy up by 2-3 L/100 kms?
Could a more complete burn of the fuel you're injecting create better MPG? Hell yes it could! Nothing curious about your new found gas mileage.
I'm surprised about valves being so loose. Ever since the invention of hydraulic lifters, valve adjustments have pretty much become void.
236,500 kms on it now. Had to replace the clutch and oem dual mass flywheel as that gave out at 220,000 kms. Stupid expensive , $5000 at Silverhill Acura. No one else in town would touch it including Clutch Pro as apparently it's a high risk/annoying job to do. Also had the front cylinder head "guts" cam, rockers etc replaced under Lubrico warranty. No oil consumption. Such a fun winter car..need some red rally armour mud flaps & a vape pen next. It's not too bad on gas although it does need 91 octane, average 10-11.5 L /100 kms with semi aggressive driving.
