I am wondering I am looking at getting my brakes done on my car, was looking at the Power stop drilled and slotted rotors along with the power stop brake pads will this be pretty good for daily driving
Yes
And will they provide better braking then new factory oem blank rotors and factory pads
Maybe? Probably? What does the website say?
OP, you don't say what vehicle, you don't say what issues you had with the factory parts, and you don't say if performance or cost is your primary decision factor. Basically, you haven't given anyone enough information to even start helping you. I rate your post 1/10 and urge you to do better.
Sorry the car is a 2013 Chevrolet impala car is daily driven and factory brakes are coming to an end that is why I am looking at replacing them also a lot of people say the brakes are undersized for the size of the car
This is what they say the pads are made from Z23 Carbon-Fiber Ceramic formula for superior braking power
You can have all the best brakes in the world, but if you are driving on OEM all season tires, the max grip from the brakes will mean nothing. Its an Impala, not a C63 AMG.
Also, its a tradeoff with regards to brake performance at cold (street) temps/brake dust/brake pad wear or disc
EDIT - yes, American cars (and trucks) seem to come with small swept areas on the discs. Upgrading to slightly bigger discs would help in long term - if its possible (not all cars have clearance).
Can the current brakes lock up the tires?
If so better brakes won’t make you stop faster. They might be smoother, feel better, give you more control, maybe handle heat better on the track. But not stop faster.
Considering your other thread, if you want to stop faster spend the money on better tires rather than brakes...
