My car (FWD 86 celica) makes squeaking noise when i turn the steering slightly or more to the left. no noise tuning the other direction (noise is coming from the front right wheel only).
any ideas guys?:dunno:
buuump:eek:
bump cmon guys plz help me out
CV joint?
metal components touching each other?
power steering pump or leak in lines.
ill put 10$ on it.
doesnt cv joints make a knocking noise if its done?
yea im 99% sure its a clicking not squeeling tooQuote:
even for turning just to one side?Quote:
ill put 10$ on it.
generallly, yes it makes a knocking as the bearings are not rotating and sliding in the channels properly. But I've heard it squeal on my last car for some reason. Maybe wheel bearing? But it generally doesn't get louder when you turn the wheel.
power steering belt!
or rotor/backing plate rubbing against rotor when you turn
i actually just got new rotors and breaks maybe a week or so before the noise started happening so i think i will look into this first then ill probably take a look at the power steering aspect of this.Quote:
Does it sound like coming from the wheel or engine bay? Low pitched squeal or high pitched?
I would like to say power steering also but.. learning more to a dry tie rod end. :P
have you hit any curbs recently?... you may have a bent axel... i lost it in my iroc one day in the rain and spun out and hit a curb... after that i had the 'squeek, squeek, squeek' when cornering.... maybe could also be a warped brake rotor perhaps?
a joint or the power steering are also very possible. more likely to be one of these if you've been driving your car relaxed...
sound seems like its coming from the wheel area not engine bay . its lower pitched.
and shizzay i did hit a curb straight on in the rain a couple months back but it was on the opposite side and there was no noise after that
did you check the backing plate? maybe its bent from your brake job? otherwise i'd say try looking at the ps belt
