this was always my biggest mistake. Now I set it to level 5 (out of 7) and lawn always looks way healthier.
Our lawn looks pretty good and the rain makes a big difference. Haven't had to use the sprinkler much. I will try to keep the cuts taller though. Golf green looks good and some of our neighbors do have flat, low cuts.
The lawn has improved a bit with all this rain, but im too late to aerate and overdress so will do it this fall. Weeds are a bit nuts but the killex with hose connection seems to do the trick just don’t have much grass taking over after it dies
Sod laid in September of last year, fertilized in the early spring and a couple weeks back. Took care of weeds and patched some thin spots a couple weeks back and its like astro-turf now.
#coupelawn
https://i.imgur.com/scsu8B1.jpg
I'm going to give the Scott's Turf Builder Max a try. Costco appears to have the best price at $1.19/lb. https://www.costco.ca/Scotts-Turf-Bu...100292895.html
Will do, I think they suggest setting 4.5 on the Scott wheeled spreader.
How does everyone prevent gas from dying along the fence/garage/house.
Maybe Motorhead moved in next door.
If it doesnt get enough sun, like a side yard between two houses, it wont grow no matter how much water, seed,fertilizer you put. Rip it out and lay fabric, then gravel. Grass needs good sun exposure
You can't force it to grow in a bad environment, no amount of water and daily fertilizer runs are going to magically make it grow if it can't get the basics. Throw in a flower bed, patio stones, or some gravel instead.
Also if it's dying right at your fence line, it could be your neighbor spraying the wrong kind of weed killer on the other side.
That's where a nice patch of creeping Charlie works well ;)
