need advice on car purchase
looking at an 85 MR2 just to get me around for now
at the moment the e-brake cable is out of the car, previous owner says it seized or locked up??? should i be worried about anything other than just replacing the cable if something like that happened? also how easy is it to put in the cable myself? i have usually worked on old bmw's and have no idea what to expect when i get under this car.
also the car is running on synthetic oil... would i be correct to take this as a good sign that the old engine can run it without causing problems or leaking oil more heavily?
im assuming this forum would be a great place to be looking for used parts and info
any other links you guys can give me for parts or do it yourself instructions? is there a certain repair manual i should grab over another?
edit: nm found the sticky :banghead:
thanks in advance
-mr2 noob
