FS: DC2 integra and misc Honda Parts
ALL ITEMS USED UNLESS STATED OTHERWISE
Integra K&N Filter OEM Fitment, works with oem air box $50 now $40
http://img231.imageshack.us/img231/1...1004131454.jpg
K&N Cone Filter Modded for OEM Fitment, works with oem air box $30 now $20
http://img512.imageshack.us/img512/3...1004131452.jpg
MSD ignition with SS coil pack, universal for any car $180 Now $160
http://img16.imageshack.us/img16/613...1004131611.jpg
P06 Converted to P28 chipped and Socketed Running ITR Base Map $180 now $160
http://img80.imageshack.us/img80/4694/p4290191.jpg
Hondata OBD2B to OBD1 conversion Harness, in above picture$100
Integra Type R clutch master cylinder with a 5/8 plunger ,works with most manual hondas $50
http://img535.imageshack.us/img535/3...1010241514.jpg
GSR Front Rotors and Calipers, for integras or civics running integra knuckles $200
http://img40.imageshack.us/img40/913...1010191719.jpg
Integra Complete dash, with climate control, center console, air bag tray delete, gauge cluster with bezel, heater blower, heater vents, and wiring harness $200
http://img411.imageshack.us/img411/6...1006031819.jpg
T1R Voltage Stabilizer (purple) $70
http://img43.imageshack.us/img43/303...helmet0008.jpg
JDM Integra Front Grill $50
http://img828.imageshack.us/img828/6...1103100048.jpg
JDM Integra headlights with chrome housing $200
http://img153.imageshack.us/img153/9...1103100052.jpg
Integra Leather Arm Rest $50
http://img695.imageshack.us/img695/6...1103100049.jpg
Integra Stock Air Box $50
http://img818.imageshack.us/img818/6...1103100050.jpg
USDM OEM ITR Integra struts and springs $300
Integra Battery, should work for most hondas $40
32mm axles from a GSR with intermediate shaft $150
Radiator with hoses and fans $50
OEM GSR cams shafts and gears $80
OEM Integra Climate Control $40
Cheap Panasonic Deck $40
TIRES
michelin energy all season205/60/r15 5/16 or 90% tread left for $300
hankook ventus summer tires 195/45/r15 5/16 or 90% tread left for $300
goodyear/ firestone all season tires 195/50/r15 3/32 or 50% tread left $100
SOLD Parts
Spoon Kevlar Spark Plug Cover
Blox 70mm Throttle body
Blox Intake Manifold port matched with 70mm TB and head
B&M Short Shifter with Energy Suspension Poly Urethane shifter bushings
Kics Gunmetal Lug Nuts
Blox 2.5" collector flange BNIB
RSX 5SPD Optional shift knob
Work Blue Lug Nuts with locks
Monroe Brake Pads for a GSR BNIB
EG Replica Spoon Mirrors with blue lens
Hytech Replica headers with big tube design and heat wrapped
NGK Blue Spark Plug wires for VTEC
B&M Fuel Pressure Regulator
Marshall fuel pressure gauge, and b&m stock fuel filter mounting kit
B18C1
Mishmoto 3 core aluminum Radiator
OEM B18C1 header with O2 sensors
OEM GSR Catback Exhaust
B16 Valve Cover Painted Yellow
bridgestone blizzaks winter tires
Low Ballers will be ignored
List will be updated as parts come off the car
PM me with Inquires
