I really want the P1 instead but don't feel like changing out a bunch of stuff for a secondary computer. The P3 is going to look so naked so I might have to splurge on LEDs.
This is the VT20 with a riced out '90s euro antenna.
Attachment 91806
Attachment 91806
The only reason I don’t have more LED fans or a cooler is because Memex is out of stock.
Thanks again. Installed a coolermaster 212 yesterday. Peak temp dropped to 60 from 85. Increased the overclock to 4.5 ghz at 1.25v, need to stress test it, but 24 hours seems excessive..
Some case porn :rofl:
Attachment 91816
Great case with the worse assembly instructions ever. Other than that, the only other issue I ran into was that the interior 3.5" tool-less HDD tray doesn't fit my 8Tb Seagate Barracuda Pro. I don't really need the drive now anyway so I might as well put it up for sale if anyone wants it.
Attachment 91815
Yay ricer builds! Looking dope guys!
Been lurking this thread because theres been some good information in here. Like someone said earlier, AMD brings out the ricer/light boi builds. My old build from 8 years ago was an i7 3770K, and that was all hidden away with no lights and a basic black case. Then during this pandemic stuff, I went down the youtube rabbit hole of looking at clean builds and the world of RGB, and then I got the bug again.
Here are the two that I've build for myself in the last couple months:
The everyday surfing/youtube/editing one. This is the one I build trying to go as clean as possible after the YouTube black hole. Gave it a "Miami Vice" kinda theme. Still on the lookout for a small model white Ferarri and then I will buy a Tubbs & Crockett Funko Pop set and set them at the bottom of the case:
Attachment 91833
Attachment 91835
Then this is the 'fun' one, the Sim Rig/Gaming box in the den. Not done yet, still awaiting the full black cable extensions to clean up/remove the colored cables for the CPU, motherboard power, and GPU power:
Attachment 91836
Attachment 91837
Awesome, a 25C drop is a really great result so you probably did a perfect job with the install. The new paste/cooler will be a huge step up compared to old paste and a stock Intel cooler.
I personally don't stress test my OC's for 24hr either but some guys like to. Never had any issues.
Glad you got it all working the way you wanted :thumbsup:
