optionJDM.com: omni power camber kits and LCA special
http://optionjdm.com/ftp/images/prod...overs/LCAs.jpg
- Made of Forged Aluminum.
- 2-2.5 lbs ligther then Stock lower control arms..
- Pressed Bushings and direct fitment.
Applications:
92-95 Civic.... 149.99 shipped CAD
96-00 Civic.... 149.99 shipped CAD
94-01 Integra... 149.99 shipped CAD
http://optionjdm.com/ftp/images/prod...nt_Large_1.jpg
Omni-Power adjustable front camber kits are designed to replace the whole factory A Arm allowing up to +- 4 degrees of camber adjustment. They come equipped with high quality ball joints and nuts able to withstand track abuse as well as the rigors of everyday street driving. These are the same kits supplied to Race Winning World Challenge Driver Roger Foo!
These Are The Same Camber Kits Used By Race Winning World Challenge Driver Roger Foo.
-Will fit all 92-95 Honda Civics, 96-00 Honda Civics & all 94-01 Acura Integras, including the Type R. These camber kits are designed to replace the whole OEM upper A arm on each side.
-This camber kit allows + or - 4 degrees of adjustablity in the front and a shim kit is provided for adjusting camber in the rear.
-They fronts also come equipped with high quality ball joints and nuts.
-Rear Shim Kit Included, Installation Instructions (fixes rear alignment)
Honda Civic 92-95 front Camber Kit with rear shims... 240.00 shipped CAD
Honda Civic 96-00 front Camber Kit wtih rear shims... 240.00 shipped CAD
Acura Integra 94-01 front Camber Kit with rear shims... 240.00 shipped CAD
