Because if you've got a cat as big and smart as one of ours, they'll just let themselves out. The locks on our screen doors keeps Larry in, leave it unlocked and he's out.
Countertops were done with rustoleum countertop transformation, one tip, tape up the supplied rollers and then remove tape. Do this a couple times and it will help to de-lint the rollers.
Backsplash is the stick on tiles. $140 for the entire thing and I did it in 2 hours. I've had success at our last house with the same product lasting 5+ years before we moved.
Dryer broke on Saturday. Had a night reserved in Banff, so fixed it today. Took it apart, the belt was broken. Also decided to check the rest of the dryer, so I took out the drum. Turns out the idler roller was also broken. Got new parts at Amre for cheap. Now works like new. Yippee.
Picked up a used ATV and a chain. Dragged a bunch of wood out of my forest. Split it. Built a small wood shack to keep it dry. Am going to finish adding walls and put a tarp over the front with hooks.
https://i.imgur.com/j2ruaDCh.jpg
https://i.imgur.com/Kx0Svg6h.jpg
https://i.imgur.com/nfKzrFyh.jpg
https://i.imgur.com/NNeUm75h.jpg
Drained the hot water tank in an effort to remove some sediment. Not sure how successful that was, but it shut off water to my dishwasher because of my "floodsafe auto shutoff connector". Had to reset that and everything works good now.
You can run into issues where sediment blocks the valve from re-seating after this and leaking.
Not saying it will, saying it can.
I think the procedure is this:
- turn gas to pilot
- close water inlet valve
- open a hot water tap on your top floor
- open drain valve
- fill and drain tank as many times as you want.
Once happy, close drain valve, open fill valve, turn gas back to "on", close hot water tap on upper floor.
If any of your appliances don't get water afterwards, you may have the same flood prevention hose I did. Shut off, disconnect, reconnect, turn back on slowly.
Installed a new dishwasher and microwave after new tile was done in the kitchen. The old microwave had a "custom" install (i.e. completely wrong) like so many things in my house. Getting it out involved cutting sheet metal and bending it out of the way as it was installed below the bottom of the upper cabinet and was holding the microwave in place. New install was pretty easy. The dishwasher was time consuming as well since I had to run a new water supply and electrical since Bosch likes to place everything opposite American manufacturers and doesn't allow for electrical connection directly to the machine, it is via a massive junction box with strip terminals. The old water line access is directly under one of the leveling feet so instead of using the dedicated hot water line it is now tee'd off the faucet supply line.
Finally installed and wired in the rest of my kitchen under-cabinet lights. They come on with the pantry light switch now.
Did a little work at a relatives house relocating a ring doorbell camera, and need suggestions on a cleaner way to finish off the old doorbell location. This is vinyl siding.
Attachment 85428
Shoot me pics with dimensions and I bet I can do something decent ;)
Mowed lawn, did some sprinkler system tweaking, and then got to cleaning patios + washing garage.
I found, that in the front yard I need a smaller, compact garden hose, that can be hidden away.
Does anyone have experience with those "expandable garden hoses"?? If so, any suggestions re a reliable one to purchase (if any?)
got more propane and bbq'd
Changed out the door gasket on my washer since the old one was covered in mold (pretty sure the old owners of this house didn’t keep the door open after washing). Also cleaned out the drain filter and detergent drawer and housing while I had it all apart.
Attachment 85477
Attachment 85478
Attachment 85479
Found $1.25 and a bunch of collar stays in the trap. Must be old owners’
Attachment 85480
Attachment 85481
Someone on the FB community page apparently didn't know that furnaces have filters. She just changed it out.
Rented a dethatcher. Holy fuck was my front yard bad, I completey filled up two compost bins with the thatch as compacted down as I could. No wonder my front lawn has been going downhill the past few years.
