Grinds Into Third After Second?
Hey guys, 02 civic si with about 92,000 k
it just started doing it the other day....when changing from second into 3rd it will grind going in...sorta seems like clutch isnt engaged all the way....Now if you are at under 4k when shifting it rarely does it..but if your over that, it grinds....
when your moving i did acouple tests...i was going about 90k....pushed the clutch in and held it in...Put it into second, then into third...and it still grinds...but from any other gear and then into third it never grinds..doesnt grind into any other gears....Do you guys think, tranny problem, clutch problem, tranny fluid problem?....
Im gonna change my tranny fluid asap n see if it works..but what do you guys think?
