Anyone know what you can do about getting the civic motor mount (2000 civic) onto the b18c block? Is there an adapter so the civic mount can bolt into the b18c?
take off the timing belt cover, take the engine mount off your civic motor and use it onto the b18c.
can't do that. you must use your original mount and drill the holes bigger until the mount is straight just like stock. we have done it a few times already and works great.Quote:
I was considering drilling the holes bigger, but I was also looking into using part of the mount from the 2000 b16a engine. If my hunch is right the bracket that connects the block to the rubber part on the chassis might be the correct bolt pattern for the b18c block mount and should fit the mount that bolts into the fender on the civic chassis. Any thoughts?
