4 Attachment(s)
2013 Honda Fit daily driver/adventure-mobile build
Hey everyone,
I thought I'd make a build thread. I've never done a car this focused on practicality before but looking at my past cars, I was always looking to increase utility wherever I could due to the nature of my profession. So here we are. 2013 Fit Sport, 5spd, in Blue Raspberry Metallic (also known as Cool Turquoise).
End goals:
- build a fun daily driver that can carve corners and have reasonable straight line speed
- build a vehicle for long distance roads trips, complete with a bed in the back
Mod list so far:
Exterior
- Enkei RF-1 – 17x7 +38 on 205/40/17 Bridgestone Blizzak WS80
- 5Zigen FN01R-C – 17x7 +42 on 205/40/17 Nexen 3000
- Muteki SR35
- 3M over hood (full), fenders (full), A-pillars (full), mirrors and up the roof
- plastidipped rear valence
- OEM gold badges
- Morimoto LED fogs with yellow Lamin-X
- IPF LED 6500k
- black window visors
- OEM JDM tail lights
- Zoom Engineering convex mirrors
Interior
- KTuned delrin shift knob
- 3D Max all season front mats, Spidermax rears
- OEM JDM red hazard switch
- OEM door sill covers
- OEM cargo cover
- OEM all weather trunk mat
- OEM Acura RDX trunk light
- OEM 08 Civic Si front seats
- Hybrid Racing CRZ shifter
Engine/Drivetrain
- 2012-2015 K24Z7 Civic Si (approx. 93k)
- 8g Civic Si alternator
- Hasport GEK mounts and axles (62A street)
- Hasport wiring harness (GE8 Fit -> 09-14 CU2 TSX)
- OEM RSX/CRV intermediate shaft
- ’09-14 Acura TSX pcm
- ’09-14 Hondata Flash Pro
- DeatschWerks RSX 265c fuel pump
- AEM short ram (8g)
- OEM RBC port and polished, with 9g fuel injector adapters (Hardmotion)
- PRL intake manifold adapter
- PRL thermal gasket
- PRL throttle body adapter
- OEM J35 Accord throttle body
- OEM RSX intermediate shaft
- Exeddy Stage 1 clutch 08806
- Exeddy flywheel HF02
- OEM replacement RSX radiator
- OEM replacement RSX fan switch
- 51R battery
- KTuned 9th gen catless downpipe
- Vibrant GESI 3” high flow cat
- Custom 2.5” exhaust
- KTuned universal swivel neck thermostat V1 (K20/K24)
- Hybrid Racing CRZ short shifter (with 9g Civic shifter cables)
- Circuit Hero lower timing chain guide
- RSX radiator
Suspension
- Progress rear sway bar
Day one. Purchased the car in BC, and drove it back and had a blast on the twisty roads
Attachment 83936
First problem identified on the road trip home - a seriously sloppy transmission mount. Thankfully Hasport is a thing. I had some fun with a make shift photo booth with this one. I would highly recommend this mount to any other Fit owner who has a manual. The whole car doesn't bounce around anymore with the bobbing transmission!
Attachment 83937
Another thing I identified was the need for convex mirrors. This is another mod I'd recommend to anyone, Fit or not. I went with Zoom Engineering convex mirrors, that are also blue to drastically reduce high beam glare. This makes driving much safer all around (you just have to keep in mind that with this mod, vehicles are much closer than they appear on BOTH sides, even the passenger side that was already convex is now even more convex). Top photos are stock, bottom photos are of the Zoom Engineering mirrors.
Attachment 83938
Now I had zero plans to modify the stock motor (K swap hopefully in the future) but I came across some HKS goodies at a price I couldn't resist! The intake adds some extra, much needed oomph in the mid to high end range. The exhaust helps on the high end as well, and as the name would imply, this is a seriously quiet exhaust. You'd only notice it at idle if you are in a garage or parkade. On the highway it is noticeable, but bearable. This is key for such a build. At wide open throttle it is definitely noticeable and fun.
HKS Racing Suction Intake
Attachment 83939
