PC wont work
Every time I turn on my PC my monitor wont turn on or display anything when I turn it on it just shuts off cause no display. So I checked my monitor on another PC and it worked fine also tried using another monitor with my PC that wont display anything on the other monitor and the same thing happens PC will turn on but monitor wont display anything when turned on.
So, does the computer tower stay on? like fans running, etc?
Or does the tower turn off after a few seconds?
Any beeping or anything?
Also check on the back of the power supply. Some of them have a switch for 110 or 220 volts, if it's set to 220 it will behave like this.
After you press the power button to turn it on, does the CD-ROM drive still open and close?
Most common causes are faulty power supply or faulty motherboard.
Yeah the tower stays on all fans running and the CD-ROM drive still opens and close.
Do you still hear the post beep? (beep when computer starts up)
Most computers make a quick beep when they first turn on. Do you recall if your computer did when it was working? Does it do that now, when you turn it on?
Did you do anything to "break" it? Or did it just stop working one day out of the blue?
I don't think I heard a beep and it just stopped working out of the blue this morning when I turned it on.
Could be a few things. Diagnosing this further requires opening the case, and probably other parts to swap in and out. Doing that on your own will void your warranty, if you have one.
We can have a tech look at it tomorrow if you'd like. Just PM me.
Your video card may have died.
i would go with Video card... pm me .. i might have one you could try and it it works ... maybe buy :)
