2 Attachment(s)
Finboy buys another Honda: 2004 Honda Element 4wd 5 speed
After a suspension revamp on the forester this year, I realized I needed a winter car to save the poor thing from a rust death. Finding something that could do all the things a forester could do was not easy, so it’s been a few months finding the right car for the right price.
Enter this:
Attachment 100728
Attachment 100729
A 2004 Honda Element 4wd 5 speed with 280k on the clock, 3 dash lights and some roof rust from a poorly installed windshield.
So what is the up side? The previous owner decided to throw all aerogenic accessories at the thing while redoing all the suspension and brakes. That means full 2” lift, subframe spacers, catalytic cage to prevent theft, spacers, winters and some 235 75 16 tires that have never been mounted. I will be moving to a lower spacer on the back end, the rake is not my taste, time to level it out.
2 Inch Aerogenics lift
Aerogenics Cat Cover
Aerogenics wheel spacer
New KYB Struts
New Control front and rear control arms
New front wheel bearings
4 x All new CV axles
4 New brake rotors and pads
4 NGK spark plugs
Valve adjustment done
4 x new Cooper AT3 tires
new oil pan seal
All new tire rod ends and bushings Moog Brand
New light bar and fog lights
All new fluids installed - Diff , Brake , Transmission and oil
Set winter tires
2 inch trailer hitch
Right now it is scheduled to get all recalls done, work on turning off the airbag light (99% sure it’s the seatbelt switch), check engine light (o2 sensor), and abs light (abs sensors in the rear). After that, hunting down some ep3 seats, rust repair the roof, and maybe learn to wrap for a colour that isn’t black. I was toying with white from the window line up, and a tan like the newer Tacoma below that, but open to options.
In other news, quality 16x8 5x114 wheels are much harder to find now a days.
More to come.
