5 Attachment(s)
Party car - now with more party
Figured I'd start a build thread here, since I feel like it's going to be an adventure.
Attachment 106540
First, let me introduce you to The Party Car AKA the Angry Jellybean AKA a 2016 Ford Fiesta ST. It's purple and loud and fun to drive. It was fully bolted with a hybrid turbo tuned by Stratified Auto out of Vancouver BC, and we put down 272 hp and 310 tq on RCTS' dyno last summer.
The car had:
Wheels and Tires
Bilstien B14 Coilovers
17” Rotiform RSE wheels
Firestone Firehawk Indy 500 tires
Mickey Thompson racing slicks/track rims
Performance/engine
Cobb accessport with protune from Stratified automotive controls
Whoosh motorsports hybrid turbo
Forge motorsports diverter valve
Mishimoto performance intake
Turbosmart 11psi wastegate
Velossa tech ram air big mouth intake with lit kit
CP-e x-flex rear engine mount
cp-eTM delta CoreTM Front Mount Intercooler
cp-eTM NexusTM Ford Fiesta ST Cat Back Exhaust
Whoosh V3 performance downpipe (3")
Mountune symposer delete
custom hydro dip engine cover done by fluid customs
Dress up bolts kit
Drivetrain
Boomba racing transmission adapter
Exterior
Avery Satin purple metallic wrap
Mountune front splitter
Maxton designs RS spoiler
iSincer Side Mirror Turn Signal Dynamic LED Lights
Diode dynamics luxeon LED fog lamps
Custom tinted headlights
Spec-D Tuning tail lights
Interior
Billetworkz aluminum shift knob
Happy Endings Tsurikawa - Purple heart
Sickspeed custom “BlairBlock” LED infinity mirror
Interior LED lighting kit
Carbon Fiber cubby hole delete
PurpGang LED “Gapplebees” Glow Panel
Last fall I blew it up at Rad Torque (fka Castrol), I really wanted to beat the guy in a Subaru again - and I did. I managed to get my best time so far, a 13.6 at 103 mph. Not bad for FWD 1.6l Turbo.
How does one blow up a Fiesta ST?
Well, they don't really like when you shift from 4 to 3 at 160 km/hr - 9000 rpms may work in Honda engines, not so much in Ford engines.
Towed it back to the house and started the teardown - it was a slow process since I've never done an engine swap in my life, so I took my time taking things apart and learning.
What was the damage?
So far, we know that all the valves are bent and I've broken the cam shaft strap over cylinder 4 - it's definitely not happy. We plan on taking the block apart further after we get the engine in from the builder.
So, what may you ask is going in the car?
Another 1.6 Litre Ford engine, however - this one is special. Ordered from Mountune in California - it is their 1.6l MRX engine - fully race prepped and forged, good for up to 400 hp.
Attachment 106543
Block:
mountune Forged Pistons and rings
mountune Forged H-beam Connecting Rods
mountune ICR Head Gasket
Cylinder Support System Block Upgrade
ARP Head Studs
Mountune Oil Control Baffle
Balanced and blueprinted
Head:
Piper stage 2 camshafts
Supertech valves and valve springs
... but since I went full send, why not actually go full send.
We have this pile of parts waiting to be installed.
Attachment 106544
In this pile:
AIRTEC Motorsport TUBULAR EXHAUST MANIFOLD - custom ceramic coated
Whoosh Intercooler Boost Hose Kit
Mishimoto Upgraded Radiator and Fan Shroud Assembly
Wavetrac Limited Slip Differential
Spec Aluminum Flywheel
Spec Clutches Stage 2+ Sprung clutch
Custom shift boot from Billetworkz
POWERFLEX Fiesta ST Front Upper Engine Mount
POWERFLEX Fiesta ST transmission mount insert
Whoosh Aluminum Shifter Base Bushings
Whoosh Transmission Cable Bracket Bushings
At this current point in time, we're waiting on the engine.
Attachment 106545
If you managed to see the car at Driven - yep, it didn't have an engine and yep, we trailered it in.
We're hoping that the engine will come in any week now, and then the fun begins!
Attachment 106546
