PC Build Thread - Page 31 - Beyond.ca - Car Forums
Page 31 of 66 FirstFirst ... 21 30 31 32 41 ... LastLast
Results 601 to 620 of 1319
Thread: PC Build Thread
  1. #601
    calgary ab
    TypeR
    At the start of the build, I had no interest in doing OC. But now that I have been doing more research and watching guys like GN and Jayz, I think it will be something I want to learn how to do, and as such, decided to get this board over something cheaper.
    I still have no idea how to do it, but the fact this thing is easy to switch BIOS and clear CMOS at the touch of a button, I am keen to learn.
    TBH its super easy to OC both cpu and gpu. Definitely recommend as you already paid for the performance. Depending on the silicon you can make some crazy gains. On my 2080ti I squeezed out an avg of 45fps on cod at 1440p putting me at 180-200 which is a game changer.
    IG:scboss
  2. #602
    rally pig
    if anyone has a 22" 1080p IPS monitor, would they be interested on trading for a 24" 1080p IPS monitor?
  3. #603
    It's super easy, just watch or read a few guides, whatever you prefer, and you shouldn't have any issues. It's hard to do any real damage even if you make a mistake.
    The latest AGESA for Ryzen actually makes automatic OC significantly better, however the Dark Hero is the only board on the market that can OC all-core boost independently from single core based on the task which is what makes it special. I would have probably bought it if I wasn't past my return period.
  4. #604
    Oct 2006
    Parked in Baygirl's garage.
    '21 F150 PowerBoost
    Yeah, I will have to look around for some guides, hopefully I can find a couple videos specific to the dark hero
    Boosted life tip #329
    Girlfriends cost money
    Turbos cost money
    Both make whining noises
    Make the smart choice.
    Originally posted by Mibz
  5. #605
    Check out de8uer on YouTube, he had a Dark Hero months ago - there might be some OC content there.
  6. #606
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    Was at MemEx picking up my 3080 that came in, the NE location got a ton of EVGA 3070(presumably XC3 variant) and a bunch of different MSI 3070 flavours. Might be a few EVGA FTW3 3080's available from people that didn't pick them up-there weren't any sitting out on the shelf when I did a quick scan. Also, there's a few FTW3 3090's and some STRIX 3090's sitting on the shelves as well.
  7. #607
    rally pig
    I'm pretty sure I'm sticking with 1440p for a while since I ordered a 27" 1440p 144hz monitor, strongly considering upgrading my 3060ti to a 3070 for future proofing or is the 3060ti good enough?
  8. #608
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    For future-proofing, go with the 3070.
    I'm running a 3070 right now with an i7-4790k on a 1080p60 screen and I'm GPU bound(only losing around 10fps or so due to the old CPU according to benchmarks) in titles like 2077 and MSFS:2020-both on max settings.
    In Control, I'm entirely GPU bound with RTX on/max settings-but I'm also getting around 120fps in that game.
    Of course-there's always going to be people that say "future proofing" isn't a real thing and that you should stick with the 3060ti. 3070 is overkill for my use case but I've averaged five years between GPU purchases so I expect them to be relevant for a long time.
  9. #609
    Some games won't even play at 144 FPS on a 3080 on high settings, so I would look at the individual games you play. If you like your settings cranked to the max, the 3070 will struggle to hit 144 FPS in quite a few games but typically you can turn a few things off and not even notice to raise the FPS. I wouldn't look too much at RT, the performance hit is enormous and there is only 2 or 3 games currently where it's even noticeable.
    The 3060Ti can be overclocked to virtually identical performance to a 3070, but of course you can also do that to a 3070.
  10. #610
    rally pig
    I'm trying to finish GTA SA right now, then the following in the backlog
    GTA IV
    The Witcher 2
    The Witcher 3
    Assassin's Creed Odyssey
    Assassin's Creed Origins
    so yeah I think 3060ti should be plenty enough haha
  11. #611
    Oct 2006
    '21 F150 PowerBoost
    My thoughts were that a 3070 should be plenty, but after reading this, I am wondering if I should bump up to a 3080...
    I mean, when I finish this rig, I want to be able to use it for the next 2-3 years playing anything i want without having to drop graphic settings in any game, and hopefully not have to upgrade anything in the next 4-5 years.
    Turbos cost money
  12. #612
    Jan 2014
    Airdrie
    '16 WRX, '23 CX-50
    If you do, lines at MemEx are getting shorter. Took me about a month to get my 3080.
  13. #613
    I always recommend people look at benchmarks for the games you currently play to help decide, and then add a bit of power for future compatibility if desired. Also, keep in mind most online testing is done with max/ultra settings, and a lot of the time you can turn down or disable certain settings to get a significant FPS bump without a noticeable change in image quality. You can forget about RT for any high FPS games, performance hit is often something like 70% so it's totally useless given that most games RT isn't even really noticeable in.
    For example, I can play COD Warzone at 140-160 FPS on my 1080Ti at 1440P with some things I don't care about turned off or lowered, and a 3070 will average around 130FPS in that game with max settings. A 3080 is only single-digit FPS better in that game on average from the benchmarks I've seen. So if you did the same with a 3070 you would be more than fine. it just highlights the need to look at individual games.
    If you want to play everything on max settings, not even a 3080 can hit 144FPS at 1440P in a lot of games without lowering some settings.
  14. #614
    Jul 2011
    Ford F150
    Truth. Even my RX580 can push those FPS numbers on lower settings. Every game is built different. I can go from Valorant and be getting 200 FPS to Tarkov and be getting 60 FPS.
    I can eat more hot wings than you.
  15. #615
    Oct 2006
    '21 F150 PowerBoost
Size:  80.1 KBName:  20210127_114822.jpg
    Went in to MemX NE, got my Dark Hero! I am posting these pics from my truck in the parking lot and they have a good stock of GPUs on the shelf. I was told I could walk out with any of them today. Lots of 3070, and about a half dozen each if 3080 and 3090 GPUs up for grabs.
    Turbos cost money
  16. #616
    Nice to see the stock crunch isn't quite as terrible as it used to be Now if only AMD could follow suit haha.
  17. #617
    Jun 2004
    21 CX5 GT Turbo
    Nice, I might try to swing by to get one for my buddy.
  18. #618
    I just noticed MemEx has a small number of Radeon 6800's in stock if anyone is looking. Probably will be gone within the hour.
  19. #619
    Moo Town
    (0^oo^0)~
    I'm thinking of getting rid of my GTX 1060 6GB. Seems like everyone is doing that and upgrading to a 30 series.
    Running it alongside an i5-8400 and X370 AORUS board.
    I hear the ASUS TUF 3070 is good shit.
  20. #620
    Jan 2009
    WRX STI
    Picked up my EVGA 3080 FTW3 from the NE MemX yesterday. Didn't think I was ever going to get it after being on the waiting list for nearly 3 months
    Still need to install but can't find extra PCIe cables. May just need to buy the individual sleeved cables to tidy everything up.
  1. Pre build or build out a pc? Need to upgrade my home desktop
    By cycosis in forum Computer Help Desk
    Latest Threads: 02-28-2020, 01:16 PM
  2. Replies: 87
  3. 92 ''Just a Civic'' Build/Story Thread
    By Sparx in forum The Garage
    Latest Threads: 04-28-2010, 05:21 PM
  4. My second silvia build thread.
    By CivicTunr in forum Nissan 240sx / Silvia Owners
    Latest Threads: 08-07-2008, 08:53 PM
  5. Silvia build thread
    Latest Threads: 04-11-2008, 08:08 PM
Tags for this Thread
