Air Conditioning for my house - Page 28 - Beyond.ca - Car Forums
Page 28 of 32 FirstFirst ... 18 27 28 29 ... LastLast
Results 541 to 560 of 630
Thread: Air Conditioning for my house
  1. #541
    Quote Originally Posted by tlapec View Post
    Whats everyone opinion on brackets vs pad for their recent AC installs? I would prefer a foundation bracket for a cleaner install but want to know if the bracket will transmit vibrations into the house?
    Mine are on brackets and didn’t notice any extra noise/vibrations personally. Even when I’m in my office which is directly inside the wall where it’s mounted I don’t notice anything.
  2. #542
    Apr 2003
    Quote Originally Posted by chongkee_ View Post
    Got an installed lined up for May 7th through Horizon Heating.
    Unit is the Carrier Performance 14, this is the slim unit.
    Cost is just over $5300 w/ tax. This includes the cost for them to fix my furnace as I had a cracked exhanger. They didn't provide me a price without the furnace fix excluded. To give you a ball park cost, W&J quoted me an additional $350 + GST to fix my furnace.
    Had quotes from W&J, Action Furnace, and Gavin.
    W&J came in the lowest at $4410 for the slim unit plus $350 + GST to fix my furnace.
    Ended up going with Horizon even though they're more expensive as they were the most thorough when they went through everything with me and they were the ones who found the issue I had on my furnace. Others didn't
    This is for a 3 ton unit and includes the electrical permit.
    How are you finding the Carrer Performance 14 slim unit after a few months? Is it quiet operation and sufficient airflow for your needs? I am getting the same exact model and in 3 ton by W&J next week. Seemed like a nice option for newer developments with the 4 ft space. Thanks.
  3. #543
    Sep 2007
    golfR
    Quote Originally Posted by Smokem View Post
    Been happy with it so far.
    It's quiet and the only time I hear it in the house is when I stand by the opposite wall. Even then the noise is minimal. When I'm in the backyard I don't hear it at all.
    Air flow is good. I have my furnace fan on 24/7 so the temperature in the whole house is pretty even.
    Tried not running the fan and just played around with the vents but I noticed a considerable difference in temperature between the main floor and 2nd floor.
  4. #544
    Apr 2003
    Very interesting, thanks for the tip on the fan and your feedback. I think for 5db and for compact size it is worth the difference. Is your house on a one-furnace, two-zone setup (i.e. thermostat upstairs and downstairs)?
  5. #545
    Sep 2007
    golfR
    I was worth it for me as I was able to shove my unit on the slimmer side of the house and still be able to walk around it.
    Being quieter is a big bonus.
    My house is a single furnace single zone with the thermostat located on the main floor. It's just under 2100 sq. ft. and south facing.
  6. #546
    Nov 2005
    A Slow Car
    Do you guys turn your ventilation fan on when you turn on the A/C or leave it on auto?
    “Straight roads are for fast cars, turns are for fast drivers.”
  7. #547
    The Gutter
    UCF20/R35
    Loving life right now, went with Armstrong Air (Lennox)
    Originally posted by rage2
    Can someone who speaks brown please translate this for me please?
  8. #548
    Bump.
    I just got an AC quote and the units were a Lennox Merit Series (78dB) and a Lennox Elite series (71dB). Does anyone here have either of these? I'm really concerned with how loud they are, but the ~50dB ones are crazy expensive so I'm hoping I can get away with 71dB. Does anyone have a sense for how loud is too loud with an AC unit in terms of decibels? I know there are other factors such as how close it is to windows, but just generally speaking. Both are single stage units, 3 ton.
    Also, for those of you what have brackets on the side of the house, does any vibration transfer into the house? I was surprised to see they don't seem to use any foam, rubber, or other dampening material on the brackets.
  9. #549
    Medicine Hat, AB
    Bump.
    10db difference will be sound as twice as loud. That said, unless its directly in the back of the house near common areas, it wont really be a problem. 78db is not much and you can have a conversation over it.
    As for the brackets, yes, it transfers vibration but its dampened and not too bad. Havent had both in difference houses, id go with the brackets again
  10. #550
    Bump.
    I have the an Elite series (EL16XC1) and when i was shopping around the noise was one of the main reasons i went with this over the Merit series (13ACX). I have it mounted to the side of the house on brackets without any other dampening material and my home office is right on the other side. I can hear it when it kicks on, but once its on it's not noticeable at all. It's the same thing when i am in the back yard - can hear a tiny sound when it turns on but after that it's essentially silent. Can't feel the vibration at all even sitting in my office.
    Overall i am very happy with the noise on the Elite series, but since i haven't heard the Merit series in person i can't really tell you its worth the extra cost. I will say that my installer was very honest (he doesn't care about upselling as his margin is the same on every model) and told me nobody has ever complained/regretted the Merit series for being too loud, so i think you would be happy either way.
    Another thing to watch out for is that if you have a newer home (built after 2015) you aren't even technically allowed to put in an a/c with lower than 14.5 SEER, so you may need to go with the Elite or better anyways:
    http://plumbingandhvac.ca/new-albert...s-take-effect/
  11. #551
    Thanks - I knew about the 10dB being a factor of double, but I was having trouble imaging what it sounds like. AC guy told me 71dB is like a microwave, which doesn't sound too bad. I feel like 71dB is louder than that, but the type of sound also matters and a low hum is probably the least offensive. 78dB I think is too loud, so I've pretty much written that one off. The unit will in fact be on the back of my house below both my and my neighbors master bedroom window (15-20ft below I guess), so I do want to make sure I get something quiet enough as to not be a nuisance. I've never seen them open their windows overnight before, but that may change when it gets hotter. I've also seen sound deadening shrouds people have installed after the fact but I have no idea how well they work or if they're necessary.
    I'm surprised they don't use some kind of rubber or foam to try and eliminate any vibrations from the brackets, but it doesn't sound like it's too bad. The AC guy said it's a non-issue but I wanted to get some opinions from owners so thanks for that.
  12. #552
    The "EL16XC" is the unit I was quoted. Not sure what the "1" on the end of yours means but maybe it was just a typo on the quote and it's the same unit.
    I didn't know about the SEER requirement, but that's good to know. Sounds like the Elite units don't have an issue there anyway.
    I'm pretty much sold on the Elite series, I was mostly hoping I didn't have to pay another $2K for the Signature series.
    That's great info though thanks.
    I've got the guy who installed my furnace when my house was built doing the work, so I think I am getting a decent price and he's already familiar with the house and the furnace.
  13. #553
    FWIW my Trane unit is 75db, and it's definitely not a noticeable noise level. You can have a normal discussion when you're standing right on top of it, and if you walk away from it around the corner of the house it's very difficult to hear it at all.
    If I've learned anything from shopping and install of AC this year, it's that paying more for higher efficiency and reduced noise of an AC unit would totally not be worth it for me. So glad I went with the entry level model.
  14. #554
    That's good to know - 71dB should be pretty reasonable then if you can barely hear 75. Thanks.
    The really high end models all seem to be dual stage (I only have a 1 stage furnace) or variable speed, which to my knowledge are designed to run constantly rather than as-needed, so the sweet spot seems to be the entry-mid range models for Calgary usage.
  15. #555
    Yeah you def don’t need a 2 stage a/c in Calgary. Only places like Arizona where you need the second stage for the summer heat while running only first stage in the winter.
  16. #556
    Wildflower Ranch
    Neo-Liberal Anarchist Mobile
    My AC guy actually talked me out of the more expensive unit. Noise doesn't bother anyone.
  17. #557
    Just got a single Lennox Elite installed - the cheap Merit systems dont come with a 10 year warranty as an option.
    ALso because we are going to end up with 2 units outside (dual furnace) we wanted to keep the over all noise down.
  18. #558
    Thanks. Sounds like a few of you have these Elite units and are happy with noise, etc. I am pretty sure I am going to pull the trigger on the EL16XC1 3 ton.
  19. #559
    I got a new quote and it looks like it's only $895 to go from the Elite EL16XC1 (71dB) to the Signature SL18XC1 (65dB) - do you guys think that's worth it? Would be about a 60% drop in noise if I am not mistaken, which at least on paper sounds significant. It's quite a bit cheaper than I was expecting so I am considering it now.
  20. #560
    I'd get the quieter unit if it was me today.
