Subwoofer trouble shooting - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Subwoofer trouble shooting
    Mar 2014
    Default Subwoofer trouble shooting
    Wondering if my aftermarket deck is on its way out or not. I got a subwoofer installed not too long ago but I started noticing that if the car is parked for a good day or so the sub won't turn on.
    I have to manually go into the settings in the deck to turn the sub settings to on. After that the sub is fine.
    Anyone know what this could be?
    Dec 2005
    not calgary
    changes every year
    Quote Originally Posted by jabjab View Post
    Is the deck a Boss brand by chance?
    Mar 2014
    nope, its a JVC. I've had it for about 5 years but never ran a subwoofer until last month.
    Feb 2003
    DT 780
    LEXUS LX470
    Maybe your alternator and battery cant keep up with your sub/amp and are drawing down battery voltage to point where deck loses settings??? No idea.
    Tap, Rack, BANG!
    Mar 2014
    I have been having issues trying to determine why my battery keeps draining, just got a new battery tho and tested for draws and shop didn't find anything. I wonder if it could be the deck still drawing power. The battery issues were happening before the sub install tho.
    Feb 2003
    DT 780
    LEXUS LX470
    I was thinking more that the alt/bat couldnt keep up while the system is in use so even if there is no phantom draw it could just not be getting enough charge
    Tap, Rack, BANG!
    Mar 2014
    I think you're on to something! I just did some research after your post and sometimes the deck isn't installed right so it constantly draws power , below is taken from a car audio forum:
    "The problem is actually the wiring. Check the installation manual, I guarantee the "pro" installer took a shortcut.
    There are two power wires (yellow & red +) and a ground wire (black -).
    Now, black goes to chassis grounding point. Easy.
    Yellow goes to a live terminal in the fuse block for constant 12V.
    This retains the settings and clock etc.
    Red goes to an ACCESSORY terminal in the fuse block (so key must be turned to at least ACC to allow it to be switched on).
    But in the case of my car, the idiot who installed it ran the red wire directly to the + battery terminal. That's wrong, and will drain the battery.
    Google for an installation manual, I'm certain your JVC head units will be the same procedure"
    now i never had a subwoofer before this battery draw thing was an issue before then. Realizing that i need to manually turn on the sub setting after a few days tells me the deck isn't storing the settings, which might be from it pulling power to the battery .
    Dec 2005
    not calgary
    changes every year
    Yep if your battery is draining, the deck will revert back to factory settings. Connect the red and orange(or yellow) together on the back of the deck to the red from the car.
    Installers are constantly connecting shit to Hot that's supposed to be to Accessory.
    I doubt the system is big enough to be drawing down the battery and alternator. That's typically getting to competition-level amounts of equipment, not just one sub.
    Deck isn't connected correctly.
    Do what 03ozwhip said. If still having issues, look at the ground wire. Run that dedicated to a bolt that is touching metal.
    I've seen ground wires do weird unexplained things when not properly grounded.
    Ground wire issues don't explain the battery drain but could explain the settings not saving.
  1. Trouble shooting my linksys WRT120N wireless router
    By 403Gemini in forum Computers, Consoles, and other Electronics
    Latest Threads: 11-21-2010, 07:40 PM
  2. Trouble shooting DT
    By Tomaz in forum Photographer's Corner
    Latest Threads: 03-09-2010, 02:37 AM
  3. trouble shooting
    By vroom6 in forum Calgary MR2 Owners Club
    Latest Threads: 02-19-2010, 07:31 PM
  4. Mac OS 10.4 Trouble shooting - Stupid Question
    By girlRACER in forum Computers, Consoles, and other Electronics
    Latest Threads: 12-25-2005, 05:12 PM
  5. civic trouble shooting plug?
    By jdms13rhd in forum Mechanical
    Latest Threads: 03-17-2004, 12:48 AM
